주요 콘텐츠로 건너뛰기
Hisense Sero 8 Motherboard Replacement
필요한 것
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Hisense Sero 8 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Hisense Sero 8 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: 2 단계, 이미지 1/2 Hisense Sero 8 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: 5 단계, 이미지 1/3 Hisense Sero 8 Motherboard Replacement: 5 단계, 이미지 2/3 Hisense Sero 8 Motherboard Replacement: 5 단계, 이미지 3/3
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
결론
Katharina
회원 가입일: 02/23/15
506 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 14
전체 시간: 1,355
