주요 콘텐츠로 건너뛰기
Hisense Sero 8 Speaker Replacement
필요한 것
  1. Hisense Sero 8 Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Hisense Sero 8 Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Hisense Sero 8 Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Remove the back cover of the device using a combination of both plastic opening tools.
    • Use your plastic opening tool to pry open a corner of the device. Continue using the tool down the side of the device to open it completely.
  2. Hisense Sero 8 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the black tape located to the left of the device.
  3. Hisense Sero 8 Speaker Replacement: 3 단계, 이미지 1/1
    • Use a Phillips head #00 screwdriver to remove the two 4.43mm screws on the bottom that keep the speakers in place.
  4. Hisense Sero 8 Speaker Replacement: 4 단계, 이미지 1/2 Hisense Sero 8 Speaker Replacement: 4 단계, 이미지 2/2
    • Unsolder the red and black wires connecting the speaker to the motherboard. Take a look at this guide to learn how to solder and unsolder connections.
  5. Hisense Sero 8 Speaker Replacement: 5 단계, 이미지 1/2 Hisense Sero 8 Speaker Replacement: 5 단계, 이미지 2/2
    • Use the spudger tool to remove the speaker panel carefully.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katharina
회원 가입일: 02/23/15
506 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 587
