주요 콘텐츠로 건너뛰기
Holmes HEH8031 Circuit Board Replacement
필요한 것
  1. Holmes HEH8031 Circuit Board Replacement, Housing: 1 단계, 이미지 1개 중 1개
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 Holmes HEH8031 Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Circuit Board Replacement, Circuit Board Removal: 4 단계, 이미지 1개 중 1개
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Circuit Board Replacement, Circuit Board: 5 단계, 이미지 3개 중 1개 Holmes HEH8031 Circuit Board Replacement, Circuit Board: 5 단계, 이미지 3개 중 2개 Holmes HEH8031 Circuit Board Replacement, Circuit Board: 5 단계, 이미지 3개 중 3개
    • Desolder the BLACK wires from the "AC-L" point and "T/S" point.
    • Learn how to solder and desolder connections here!
    • Desolder the WHITE wire from the "AC-N" point.
    • Desolder the RED wire from the "FAN-RED".
    • Desolder the GREY wire from the "24V" point.
    • Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
    • Be sure to use desoldering wick when you remove the wire connections.
  6. Holmes HEH8031 Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Holmes HEH8031 Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chris Shaffer
회원 가입일: 10/12/16
255 평판
안내서 2개를 작성함
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G1
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 1,161
