소개
This is a very simple guide that will help you dissasemble and replace the motor of your Holmes box fan, this process is easy and it only requires a screwdriver and a new motor to install.
필요한 것
The first step is to make sure you unplug your fan from the outlet.
Make sure you also unplug the power cord from the back of the fan.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 4개
Where might one find a replacement motor for a older box fan
Chris Cook - 답글
Also, I would like to know where to get a replacement motor, as shown in step 4.
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - 답글
My plug won’t unplug from the back of the fan what do I do? How should I try to get it out. The plug is really stuck in their.
Marisol Walls - 답글
