주요 콘텐츠로 건너뛰기
Holmes box fan motor replacement
필요한 것
  1. Holmes box fan motor replacement, Motor: 1 단계, 이미지 3개 중 1개 Holmes box fan motor replacement, Motor: 1 단계, 이미지 3개 중 2개 Holmes box fan motor replacement, Motor: 1 단계, 이미지 3개 중 3개
    • The first step is to make sure you unplug your fan from the outlet.
    • Make sure you also unplug the power cord from the back of the fan.
    My plug won’t unplug from the back of the fan what do I do? How should I try to get it out. The plug is really stuck in their.
    Marisol Walls - 답글
  2. Holmes box fan motor replacement: 2 단계, 이미지 2개 중 1개 Holmes box fan motor replacement: 2 단계, 이미지 2개 중 2개
    • Now that your fan is unplugged, lay it flat with the brand label facing upward.
    • Next is to remove the front cover.
    • Remove the six screws from the perimeter of the cover in order to remove the front cover.
  3. Holmes box fan motor replacement: 3 단계, 이미지 2개 중 1개 Holmes box fan motor replacement: 3 단계, 이미지 2개 중 2개
    • Next is the back cover.
    • Flip over the fan so you have access to these six screws.
    • Remove the six screws from the perimeter of the cover in order to remove the back cover.
  4. Holmes box fan motor replacement: 4 단계, 이미지 1개 중 1개
    • Remove these four screws in order to remove the motor and fan blades from the housing.
  5. Holmes box fan motor replacement: 5 단계, 이미지 1개 중 1개
    • The housing should now be able to lift away from the motor and fan blade.
  6. Holmes box fan motor replacement: 6 단계, 이미지 3개 중 1개 Holmes box fan motor replacement: 6 단계, 이미지 3개 중 2개 Holmes box fan motor replacement: 6 단계, 이미지 3개 중 3개
    • The next step is to remove the mounts that held the motor to the housing.
    • Remove these four screws to remove the mounts.
  7. Holmes box fan motor replacement: 7 단계, 이미지 2개 중 1개 Holmes box fan motor replacement: 7 단계, 이미지 2개 중 2개
    • Now you are able to remove the motor from the fan blades.
    • Be careful, if you used your fan recently the motor may be quite hot.
  8. Holmes box fan motor replacement: 8 단계, 이미지 1개 중 1개
    • Now you can insert your new motor and you are done!
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Max Cossalter
회원 가입일: 09/29/15
341 평판
안내서 1개를 작성함
Cal Poly, Team 15-4, Green Fall 2015 Cal Poly, Team 15-4, Green Fall 2015 회원
CPSU-GREEN-F15S15G4
4 회원들
안내서 4개를 작성함
댓글 5개
Where might one find a replacement motor for a older box fan
Chris Cook - 답글
Also, I would like to know where to get a replacement motor, as shown in step 4.
Vince Doriean - 답글
Great guide! Upon reassembling, I noticed that the center of the propeller touches the front grill where it says Holmes. Anyone know if they rub on each other by design?
Zeev - 답글
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - 답글
Also want to know where to find this kind of replacement motor?
Bridget Alice Alonso - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 23
전체 시간: 13,010
