소개
Replacing an air filter is a common task every car owner will likely need to complete at some point in their lives. If you haven’t replaced your air filter in quite some time, or if a mechanic tells you that your air filter is in need of replacement, don’t fret! This is a repair you can easily complete yourself. Replacing the air filter will improve the air quality inside your cabin.
필요한 것
Ensure that your 2016 Honda CR-V Touring Edition is off.
Open the glovebox and remove all of its contents.
다른 2명이 해당 안내서를 완성하였습니다.
