주요 콘텐츠로 건너뛰기
Honda CR-V Touring 2016 Cabin Air Filter Replacement
필요한 것
  1. Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 3/3
    • Ensure that your 2016 Honda CR-V Touring Edition is off.
    • Open the glovebox and remove all of its contents.
  2. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 2 단계, 이미지 1/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 2 단계, 이미지 2/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 2 단계, 이미지 3/3
    • Unfasten the hinge on the right side of your glovebox so the hook-part of the hinge is free and clear.
    • You may have to close the glovebox slightly, then open it fully while holding the hook to clear it.
  3. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 3 단계, 이미지 1/2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 3 단계, 이미지 2/2
    • Push both sides of the glovebox together while lowering until the glovebox hangs at its lowest point.
    • This should allow access to the interior and give a clear line of sight to the cabin air filter holder.
  4. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 4 단계, 이미지 1/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 4 단계, 이미지 2/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • Grasp both clasps on either side of the rectangular cabin air filter protective cover and pull to release the cover.
    • You should see a white filter.
  5. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 5 단계, 이미지 1/2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 5 단계, 이미지 2/2
    • Pull the filter straight out until it is free and clear.
    • Be sure not to shake it to prevent any excess dust from falling.
  6. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 6 단계, 이미지 1/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 6 단계, 이미지 2/3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 6 단계, 이미지 3/3
    • Insert the new filter, taking care to orient the filter in the correct direction for airflow.
    • It will be marked with arrows both on the filter and below the location for the filter.
  7. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 7 단계, 이미지 1/2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 7 단계, 이미지 2/2
    • Place the cabin air filter protective cover over top of the filter until you hear audible clicks from the clasps engaging.
  8. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 8 단계, 이미지 1/2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 8 단계, 이미지 2/2
    • Push the glovebox up until you feel a detent where it is self supported but is not fully in the up-position.
  9. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 9 단계, 이미지 1/2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 9 단계, 이미지 2/2
    • Re-clip the hook on the right side of the glovebox until it is fully engaged.
  10. Honda CR-V Touring 2016 Cabin Air Filter Replacement: 10 단계, 이미지 1/2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: 10 단계, 이미지 2/2
    • Close the glovebox and you're all set!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Oliver Du Bois
회원 가입일: 01/29/20
223 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 34
전체 시간: 1,605
