소개
This guide shows how to remove and replace the carburetor for the Honda EU2200IT generator.
Fuel may leak out of the carburetor during this procedure. Be sure to have tools at hand to contain any spillage.
You should replace the air intake and carburetor gaskets during this procedure.
필요한 것
Use a Phillips #2 screwdriver to loosen the screw holding the maintenance cover in place.
Place a container below the drain tube to catch the excess fuel.
Use a flathead screwdriver to loosen the breather tube from the air cleaner housing.
Disconnect the breather tube from the air cleaner housing.
Use a pair of pliers to squeeze and slide the spring clip off the carburetor fuel intake.
다른 2명이 해당 안내서를 완성하였습니다.
