주요 콘텐츠로 건너뛰기
Hover-1 Charger Bluetooth Speaker Replacement
필요한 것
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: 1 단계, 이미지 1/2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: 1 단계, 이미지 2/2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: 2 단계, 이미지 1/1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: 3 단계, 이미지 1/2 Hover-1 Charger Bluetooth Speaker Replacement: 3 단계, 이미지 2/2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: 4 단계, 이미지 1/1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: 5 단계, 이미지 1/2 Hover-1 Charger Bluetooth Speaker Replacement: 5 단계, 이미지 2/2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: 6 단계, 이미지 1/1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: 7 단계, 이미지 1/2 Hover-1 Charger Bluetooth Speaker Replacement: 7 단계, 이미지 2/2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: 8 단계, 이미지 1/2 Hover-1 Charger Bluetooth Speaker Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: 9 단계, 이미지 1/2 Hover-1 Charger Bluetooth Speaker Replacement: 9 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: 10 단계, 이미지 1/1
    • Remove the speaker and circuit board from the outer shell.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryson Shishido
회원 가입일: 10/10/19
145 평판
안내서 1개 작성함
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 회원
CPSU-REGAN-F19S12G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 19
전체 시간: 1,292
