주요 콘텐츠로 건너뛰기
Hover-1 Charger LED Headlight Replacement
필요한 것
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: 1 단계, 이미지 1/2 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: 1 단계, 이미지 2/2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: 2 단계, 이미지 1/1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: 3 단계, 이미지 1/2 Hover-1 Charger LED Headlight Replacement: 3 단계, 이미지 2/2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: 4 단계, 이미지 1/1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: 5 단계, 이미지 1/2 Hover-1 Charger LED Headlight Replacement: 5 단계, 이미지 2/2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: 6 단계, 이미지 1/2 Hover-1 Charger LED Headlight Replacement, LED Headlight: 6 단계, 이미지 2/2
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: 7 단계, 이미지 1/2 Hover-1 Charger LED Headlight Replacement: 7 단계, 이미지 2/2
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: 8 단계, 이미지 1/1
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
결론
Benji Forest
회원 가입일: 10/10/19
266 평판
안내서 2개 작성하였습니다
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 회원
CPSU-REGAN-F19S12G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 206
