소개
In order for your Hover-1 Coast to be used, you must have a functioning controller. It is essential to have a fully functioning controller for the Hover-1 Coast to be used to it's full potential. This guide is not too difficult and can be done by anyone.
  1. Identify the three screws and using a Phillips #1 screwdriver loosen the the screws.
    • Identify the three screws and using a Phillips #1 screwdriver loosen the the screws.
    • Remove the three screws.
  2. Pull the backside of the controller off.
    • Pull the backside of the controller off.
    • The inside of the controller should look like this.
    • The marked area is the battery.
    • Remove the black foam piece covering the battery.
    • Desolder the battery connections from the motherboard.
    • Using a plastic opening tool, pry the battery off the motherboard.
결론
Jace Oppenlander
회원 가입일: 2018년 10월 04일
521 평판
안내서 4개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 43
전체 시간: 68
