주요 콘텐츠로 건너뛰기
Hover-1 Eagle Back Wheel Replacement
필요한 것
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: 1 단계, 이미지 1/1
    • Peel off the reflective red axle sticker using a plastic spudger.
  2. Hover-1 Eagle Back Wheel Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
  3. Hover-1 Eagle Back Wheel Replacement: 3 단계, 이미지 1/3 Hover-1 Eagle Back Wheel Replacement: 3 단계, 이미지 2/3 Hover-1 Eagle Back Wheel Replacement: 3 단계, 이미지 3/3
    • Grip the deck flare and slide it towards the tail end of the scooter.
  4. Hover-1 Eagle Back Wheel Replacement: 4 단계, 이미지 1/1
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
  5. Hover-1 Eagle Back Wheel Replacement: 5 단계, 이미지 1/3 Hover-1 Eagle Back Wheel Replacement: 5 단계, 이미지 2/3 Hover-1 Eagle Back Wheel Replacement: 5 단계, 이미지 3/3
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
  6. Hover-1 Eagle Back Wheel Replacement: 6 단계, 이미지 1/2 Hover-1 Eagle Back Wheel Replacement: 6 단계, 이미지 2/2
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
결론
To reassemble your device, repeat Steps 1-4 in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Andrew Gaskell
회원 가입일: 01/23/20
1,008 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 회원
CPSU-WHITE-W20S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where do you buy the wheels
Thanks
antonio flores - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 45
전체 시간: 2,393
