주요 콘텐츠로 건너뛰기
Hover-1 Eagle Front Wheel Replacement
필요한 것
  1. Hover-1 Eagle Front Wheel Replacement, Front Wheel: 1 단계, 이미지 1개 중 1개
    • Wedge the spudger underneath the red reflective sticker and peel it back.
  2. Hover-1 Eagle Front Wheel Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Eagle Front Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 2mm screws with a Phillips #2 screwdriver.
  3. Hover-1 Eagle Front Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the plastic axle cover by sliding the cover downwards.
  4. Hover-1 Eagle Front Wheel Replacement: 4 단계, 이미지 1개 중 1개
    • Use pliers to remove the locknut.
  5. Hover-1 Eagle Front Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the wheel out in a downwards motion to remove it from the fork.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Andrew Gaskell
회원 가입일: 01/23/20
1,137 평판
안내서 5개를 작성함
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 회원
CPSU-WHITE-W20S1G2
4 회원들
안내서 6개를 작성함
18가이드 댓글
Good afternoon.
And how do you remove the cables?
Diogo Silva - 답글
i would like to know the same thing
it'sluigiplays 87 - 답글
where do i get the front wheel front i cant find where to buy a new front wheel
leon watts - 답글
I would like to know as well how to take the cable out from harness. Do you have to remove everything from the battery and disconnect the throttle as well?
Mk Sub-zero - 답글
Does anybody know how to fix the handlebar/front wheel alignment?
robandkim - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 32
전체 시간: 7,343
