주요 콘텐츠로 건너뛰기
Hover-1 Eagle LED Headlight Replacement
필요한 것
  1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: 1 단계, 이미지 1/3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: 1 단계, 이미지 2/3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: 1 단계, 이미지 3/3
    • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
  2. Hover-1 Eagle LED Headlight Replacement: 2 단계, 이미지 1/3 Hover-1 Eagle LED Headlight Replacement: 2 단계, 이미지 2/3 Hover-1 Eagle LED Headlight Replacement: 2 단계, 이미지 3/3
    • Carefully remove the top of the housing containing the display screen.
    • Remove the top of the housing slowly to avoid damaging the wires.
  3. Hover-1 Eagle LED Headlight Replacement: 3 단계, 이미지 1/2 Hover-1 Eagle LED Headlight Replacement: 3 단계, 이미지 2/2
    • Slide the LED light cover upwards out of the display housing
    • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
    • The LED circuit board should slide out with the LED light cover.
    • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
  4. Hover-1 Eagle LED Headlight Replacement: 4 단계, 이미지 1/3 Hover-1 Eagle LED Headlight Replacement: 4 단계, 이미지 2/3 Hover-1 Eagle LED Headlight Replacement: 4 단계, 이미지 3/3
    • Using a soldering iron, desolder the black and red wires from the LED circuit board.
    • To reassemble, solder the same black and red wires onto the new LED circuit board.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Andrew Gaskell
회원 가입일: 01/23/20
1,008 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 회원
CPSU-WHITE-W20S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 1,084
