주요 콘텐츠로 건너뛰기
Hover-1 Eagle Throttle/Brake Lever Replacement
필요한 것
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 1 단계, 이미지 1/3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 1 단계, 이미지 2/3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: 1 단계, 이미지 3/3
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: 2 단계, 이미지 1/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 2 단계, 이미지 2/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 2 단계, 이미지 3/3
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: 3 단계, 이미지 1/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 3 단계, 이미지 2/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 3 단계, 이미지 3/3
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: 4 단계, 이미지 1/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 4 단계, 이미지 2/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 4 단계, 이미지 3/3
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: 5 단계, 이미지 1/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 5 단계, 이미지 2/3 Hover-1 Eagle Throttle/Brake Lever Replacement: 5 단계, 이미지 3/3
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Andrew Gaskell
회원 가입일: 01/23/20
1,008 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 회원
CPSU-WHITE-W20S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 24개
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - 답글
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - 답글
Necesito acelerador y no lo encuentro.
Josue Villanueva - 답글
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 111
전체 시간: 15,649
