이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide for the Hover-1 Maverick guides users in replacing the battery in their device. The battery is crucial in powering the hoverboard. Symptoms of having a faulty battery include the device not being able to move, hold a charge, or power on.
필요한 것
Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
Remove the shell.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
