주요 콘텐츠로 건너뛰기
How To Repair An Overheating D-LINK DIR-655 Wireless Router
필요한 것
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: 1 단계, 이미지 2개 중 1개 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: 1 단계, 이미지 2개 중 2개
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 2 단계, 이미지 2개 중 1개 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 2 단계, 이미지 2개 중 2개
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 3 단계, 이미지 3개 중 1개 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 3 단계, 이미지 3개 중 2개 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 3 단계, 이미지 3개 중 3개
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 4 단계, 이미지 1개 중 1개
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 5 단계, 이미지 2개 중 1개 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 5 단계, 이미지 2개 중 2개
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 6 단계, 이미지 1개 중 1개
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 7 단계, 이미지 3개 중 1개 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 7 단계, 이미지 3개 중 2개 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 7 단계, 이미지 3개 중 3개
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 8 단계, 이미지 1개 중 1개
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 9 단계, 이미지 1개 중 1개
    • Wipe away any dust from the the vents to ensure proper airflow.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chance Daniel
회원 가입일: 09/29/15
263 평판
안내서 1개를 작성함
Cal Poly, Team 10-6, Green Fall 2015 Cal Poly, Team 10-6, Green Fall 2015 회원
CPSU-GREEN-F15S10G6
3 회원들
안내서 3개를 작성함
댓글 한 개
Fixed my unit :-)
larry_wollen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 5,641
