주요 콘텐츠로 건너뛰기
How To Replace Merangue 2-Line Engineering Scientific Calculator Battery
필요한 것
  1. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery, Calculator Battery: 1 단계, 이미지 1개 중 1개
    • Turn the calculator off by holding down the [Shift] button.
    • Then, press the [AC][OFF] button.
    • Always turn your calculator off before removing the battery to prevent potential malfunction.
  2. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 2 단계, 이미지 2개 중 1개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 2 단계, 이미지 2개 중 2개
    • Flip the calculator so that the back case is facing you.
    • Use a Phillips #0 screwdriver to remove the single screw from the battery cover at the top of the back case.
    • Keep the screw in a safe place to use when replacing the battery cover later.
    • If the screw does not unfasten easily, do not force it to avoid stripping the screw. If the screw is already stripped refer to the 마모된 나사 분리 방법 guide.
  3. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 3 단계, 이미지 3개 중 1개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 3 단계, 이미지 3개 중 2개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 3 단계, 이미지 3개 중 3개
    • Gently apply pressure to the battery cover and slide it upward.
    • If it doesn't come off easily, try gently wiggling it but do not use excessive force.
  4. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 4 단계, 이미지 3개 중 1개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 4 단계, 이미지 3개 중 2개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 4 단계, 이미지 3개 중 3개
    • Insert a plastic spudger between the two batteries.
    • Use the plastic spudger to gently pry out the left and right batteries.
    • Do not use metal spudgers, as they can damage to the battery.
    • Do not use force when prying out the batteries to avoid damage.
  5. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 5 단계, 이미지 1개 중 1개
    • Put on the nitrile gloves and remove the two batteries from the battery compartment.
    • To dispose of the battery properly consult the How to Recycle End-of-Life Electronics article.
    • Always wear a pair of gloves prior to handling the battery to reduce the risk of chemical burns.
  6. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 6 단계, 이미지 1개 중 1개
    • Inspect the battery compartment for any sign of alkaline residue.
    • If the area is clean, skip to step 8.
  7. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 7 단계, 이미지 3개 중 1개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 7 단계, 이미지 3개 중 2개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 7 단계, 이미지 3개 중 3개
    • Dab a cotton swab in distilled white vinegar.
    • Gently clean the battery compartment in an up and down motion with the cotton swab.
    • Allow the compartment to dry completely for approximately two minutes before inserting the new batteries.
  8. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 8 단계, 이미지 1개 중 1개
    • Insert the new LR 1130 batteries in both slots.
    • Make sure the + sign on the battery is facing down in its respective slot.
  9. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 9 단계, 이미지 3개 중 1개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 9 단계, 이미지 3개 중 2개 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 9 단계, 이미지 3개 중 3개
    • Slide the battery cover back into place.
    • Use a Phillips #0 screwdriver to secure the battery cover screw.
  10. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 10 단계, 이미지 1개 중 1개
    • Reset the calculator by pressing the [ON] button.
    • Release the [ON] button and press [Shift].
    • Release the [Shift] button and press the [MODE] button.
    • Release the [MODE] button and press the [3] button to reset all.
    • Release the [3] button and press [=] to confirm the action.
    • Finally, release the [=] button and press the [AC] button to complete the reset.
결론
You have now successfully replaced the battery of a Merangue 2-Line Engineering Scientific Calculator.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Lakshan.14
회원 가입일: 07/02/24
235 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 29
전체 시간: 440
