주요 콘텐츠로 건너뛰기
How To Replace the Battery on a Conair Trimmer (GMT15NCS)
필요한 것
  1. How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: 1 단계, 이미지 3개 중 1개 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: 1 단계, 이미지 3개 중 2개 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: 1 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove the two screws holding the trimmer blade in place.
    • Hold down the trimmer blades to make it easier to remove the screws.
  2. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 2 단계, 이미지 2개 중 1개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 2 단계, 이미지 2개 중 2개
    • Lift both of the trimmer blades off of the plastic guard.
  3. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 3 단계, 이미지 3개 중 1개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 3 단계, 이미지 3개 중 2개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 3 단계, 이미지 3개 중 3개
    • Separate the plastic guard from the casing by using the metal spudger tool.
    • Pry up at the top of the plastic guard, NOT the bottom.
  4. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 4 단계, 이미지 2개 중 1개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 4 단계, 이미지 2개 중 2개
    • Using a Phillips #000 screwdriver, remove the two screws inside the casing.
    • Tilt the trimmer to prevent the screws from falling into the casing.
  5. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 5 단계, 이미지 1개 중 1개
    • Using a Phillips #000 screwdriver, remove the casing screw at the bottom of the trimmer.
    • Tilt the trimmer so gravity helps the screw fall out.
  6. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 6 단계, 이미지 3개 중 1개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 6 단계, 이미지 3개 중 2개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 6 단계, 이미지 3개 중 3개
    • Fire Hazard: Be careful not to stick the metal spudger too deep when prying to avoid puncturing the battery.
    • Separate the casing at the seam using the metal spudger to release the clips.
    • Use a twisting or prying motion, in any direction, to separate the casing.
    • The same process may be needed on the other side's seam to release clips.
  7. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 7 단계, 이미지 3개 중 1개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 7 단계, 이미지 3개 중 2개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 7 단계, 이미지 3개 중 3개
    • Remove the two screws holding the battery setup in place.
    • Take note of the position of the positive and negative terminals of the battery on the setup.
  8. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 8 단계, 이미지 1개 중 1개
    • Lift the battery setup out of the casing.
    • Take note of how the battery setup lays in the casing.
  9. How To Replace the Battery on a Conair Trimmer (GMT15NCS): 9 단계, 이미지 3개 중 1개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 9 단계, 이미지 3개 중 2개 How To Replace the Battery on a Conair Trimmer (GMT15NCS): 9 단계, 이미지 3개 중 3개
    • The soldering iron with be hot.
    • Using the soldering iron, desolder the battery at the connection to remove the battery from the setup.
    • Use iFixit's guide on 연결부 납땜 및 납제거 방법 if you are not familiar using a soldering tool.
결론
To reassemble your device, solder the new 2.4 V battery into the setup, and follow the instructions in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nicholas Ellis
회원 가입일: 02/20/19
223 평판
안내서 1개를 작성함
댓글 한 개
Where can I buy the batery
Wenceslao Hernandez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 52
지난 30일: 170
전체 시간: 11,168
