주요 콘텐츠로 건너뛰기
How To Use Screen Vise Clamps
필요한 것
  1. How To Use Screen Vise Clamps, Fit your device into a clamp: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Screen Vise Clamps 6-Pack
    $25.95
    • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of your device.
    • Do not use vise clamps to forcibly close a bulging device.
    • Before beginning this repair, we recommend cleaning your device to avoid catching debris between the vise jaws and the device.
    • Open a screen vise clamp and slide it over the edge of your device, as far as it will go.
  2. How To Use Screen Vise Clamps: 2 단계, 이미지 2개 중 1개 How To Use Screen Vise Clamps: 2 단계, 이미지 2개 중 2개
    • If your device has a camera bump and the clamp is able to sit squarely over the center of a lens, you only need to use one clamp for the camera bump.
    • If the clamp is not able to sit squarely over the center of a lens, use two clamps spaced evenly over the camera bump.
  3. How To Use Screen Vise Clamps: 3 단계, 이미지 2개 중 1개 How To Use Screen Vise Clamps: 3 단계, 이미지 2개 중 2개
    • For watches, place clamps near the edges, and make sure the jaws press down flat on the display and not at an angle.
  4. How To Use Screen Vise Clamps, Lightly secure the clamp: 4 단계, 이미지 2개 중 1개 How To Use Screen Vise Clamps, Lightly secure the clamp: 4 단계, 이미지 2개 중 2개
    • Over-tightening may damage your device's screen or back cover.
    • Spin the vise clamp knob clockwise to lower the upper jaw onto the screen.
    • Spin the knob until the jaw makes light contact with the screen, and then tighten down one half turn.
    • The clamp isn't meant to be very tight just yet.
  5. How To Use Screen Vise Clamps: 5 단계, 이미지 3개 중 1개 How To Use Screen Vise Clamps: 5 단계, 이미지 3개 중 2개 How To Use Screen Vise Clamps: 5 단계, 이미지 3개 중 3개
    • Repeat the previous steps for the five remaining vise clamps: one at each of the four corners, and one in the middle of each long edge.
    • For larger tablets, more than six vise clamps may be needed to ensure the adhesive bonds evenly around the entire perimeter.
    • Using a hair dryer or heat gun, evenly heat the edges all the way around the device until they are slightly too hot to touch. The heat will help the adhesive form a more complete bond.
    • Don't overheat the device, or you may cause the battery to ignite or damage other heat-sensitive components, like the display.
    • While the device is still hot, tighten all six vise clamps down one full turn.
    • Don't tighten any further to avoid damaging your device.
    • Leave the vise clamps in place for about thirty minutes.
결승점
다른 28명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
155,514 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 101
지난 30일: 426
전체 시간: 22,551
