주요 콘텐츠로 건너뛰기
How to Apply Flash Unit Adhesives in Your Google Pixel 8a
필요한 것
  1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: 1 단계, 이미지 1/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: 1 단계, 이미지 2/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: 1 단계, 이미지 3/3
    • Use tweezers to remove the conductive tape adhesive from the top right corner of the motherboard cover.
    • Use the flat end of a spudger to scrape up any remaining bits of adhesive.
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the adhesive residue and wipe it away with a microfiber cloth.
  2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 2 단계, 이미지 1/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 2 단계, 이미지 2/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 2 단계, 이미지 3/3
    • Remove the conductive tape adhesive from its larger clear backing and put it into place with the tab on the right.
    • Use the flat end of a spudger to press down and secure the conductive tape.
    • Remove the remaining liner.
  3. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: 3 단계, 이미지 1/2 How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: 3 단계, 이미지 2/2
    • Check the condition of the adhesive on the bottom of the flash unit.
    • If the adhesive is undamaged and still sticky, you can skip the rest of this guide and return to your original repair guide.
    • If the adhesive is damaged or no longer sticky, follow the next three steps to replace it.
  4. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 4 단계, 이미지 1/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 4 단계, 이미지 2/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 4 단계, 이미지 3/3
    • During the remaining steps, be very careful not to strain or tear the delicate flash unit cable.
    • Use a spudger and tweezers to carefully scrape up and remove the old adhesive from the bottom of the flash unit.
  5. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 5 단계, 이미지 1/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 5 단계, 이미지 2/3 How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 5 단계, 이미지 3/3
    • Remove the flash unit adhesive from its larger, clear liner and put it into place on the bottom of the flash unit.
    • Use the flat end of a spudger to press down and secure the adhesive.
  6. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: 6 단계, 이미지 1/1
    • Firmly press the flash unit into place on the logic board cover to secure it with the adhesive.
    • Return to your original guide and continue with reassembly.
결론
Spencer Day
회원 가입일: 09/14/22
59,598 평판
안내서 430개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,850개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 44
전체 시간: 60
