주요 콘텐츠로 건너뛰기
How to Apply New Back Glass Adhesive in Your Google Pixel Fold
필요한 것
  1. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: 1 단계, 이미지 3개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: 1 단계, 이미지 3개 중 2개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: 1 단계, 이미지 3개 중 3개
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
    • Look for cutouts in the liner to help orient the adhesive.
  2. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: 2 단계, 이미지 3개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: 2 단계, 이미지 3개 중 2개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: 2 단계, 이미지 3개 중 3개
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel off the new adhesive strip from its clear liner.
    • Align the adhesive over the frame, starting with the top right and bottom right edges.
    • Place the adhesive over the perimeter of the frame.
  3. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 3 단계, 이미지 3개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 3 단계, 이미지 3개 중 2개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 3 단계, 이미지 3개 중 3개
    • Use flat end of a spudger, or your fingers, to press down the adhesive to adhere it to the frame.
  4. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the large liner: 4 단계, 이미지 2개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the large liner: 4 단계, 이미지 2개 중 2개
    • Peel up the segmented tab at the bottom right corner of the large blue liner.
  5. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 5 단계, 이미지 2개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 5 단계, 이미지 2개 중 2개
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
  6. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Reconnect the back glass: 6 단계, 이미지 2개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Reconnect the back glass: 6 단계, 이미지 2개 중 2개
    • Support the back glass with your hand or prop it up on something sturdy.
    • Reconnect the back glass cable.
    • Use a Torx Plus 3IP driver to refasten the middle bracket.
  7. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the secondary liner: 7 단계, 이미지 2개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the secondary liner: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to peel up either one of the tabs at the top right corner of the secondary liner.
    • If the adhesive starts separating, use a spudger to hold it down while peeling.
  8. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 8 단계, 이미지 3개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 8 단계, 이미지 3개 중 2개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 8 단계, 이미지 3개 중 3개
    • Lift the tab and peel off the secondary liner to expose the top adhesive.
  9. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: 9 단계, 이미지 3개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: 9 단계, 이미지 3개 중 2개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: 9 단계, 이미지 3개 중 3개
    • Align the back glass over its cutout in the frame.
    • Place a long edge of the back glass on the frame, making sure there are no gaps or jutting adhesive.
    • Place the other long edge of the back glass on the frame.
  10. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 10 단계, 이미지 3개 중 1개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 10 단계, 이미지 3개 중 2개 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: 10 단계, 이미지 3개 중 3개
    • Press down along the perimeter of the back glass to adhere it to the frame.
    • Let the phone sit a few hours for the adhesive to cure.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,813 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,611개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 548
