주요 콘텐츠로 건너뛰기
How to Apply New Flip Battery Adhesive in Your Google Pixel Fold
필요한 것
  1. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Remove the old adhesive: 1 단계, 이미지 2개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Remove the old adhesive: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the frame.
    • Use the flat end of a spudger and tweezers to remove the remaining adhesive residue from the frame.
    • Wipe off any remaining isopropyl alcohol with a lint-free or microfiber cloth.
  2. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold: 2 단계, 이미지 3개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold: 2 단계, 이미지 3개 중 2개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold: 2 단계, 이미지 3개 중 3개
    • Place the new adhesive strips over the frame to check the proper orientation.
    • The clear liners should face the frame.
    • Use the white lines on the frame to align the adhesive strip corners.
  3. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Expose the adhesive: 3 단계, 이미지 3개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Expose the adhesive: 3 단계, 이미지 3개 중 2개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Expose the adhesive: 3 단계, 이미지 3개 중 3개
    • Peel off the new adhesive strips from their clear liners.
  4. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Apply the adhesive: 4 단계, 이미지 2개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Apply the adhesive: 4 단계, 이미지 2개 중 2개
    • Be careful with this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Apply the adhesive strips to their respective spots on the frame.
    • Make sure the black tabs on the left-most adhesive strip don't overlap where the screen adhesive sits.
  5. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold: 5 단계, 이미지 3개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold: 5 단계, 이미지 3개 중 2개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold: 5 단계, 이미지 3개 중 3개
    • Use a spudger, or your fingers, to press down the three adhesive strips to adhere them.
    • Fold over the black tabs on the left-most adhesive strip onto the frame.
  6. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Remove the liners: 6 단계, 이미지 3개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Remove the liners: 6 단계, 이미지 3개 중 2개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Remove the liners: 6 단계, 이미지 3개 중 3개
    • Remove the blue liners on the adhesive strips to expose the top adhesive.
  7. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Secure the battery: 7 단계, 이미지 3개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Secure the battery: 7 단계, 이미지 3개 중 2개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Secure the battery: 7 단계, 이미지 3개 중 3개
    • Reconnect the battery cable temporarily to make sure the battery is aligned properly.
    • Place the battery in its recess, making sure to align it as close to the top edge of the recess lip as possible.
    • Press down on the battery to adhere it to the frame.
    • Make sure the battery is disconnected before continuing your repair.
  8. How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Secure the cable: 8 단계, 이미지 3개 중 1개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Secure the cable: 8 단계, 이미지 3개 중 2개 How to Apply New Flip Battery Adhesive in Your Google Pixel Fold, Secure the cable: 8 단계, 이미지 3개 중 3개
    • Peel off the blue liner on the middle black tab near the battery connector.
    • Fold the black tab onto the bottom edge of the battery.
    • Press down on the battery cable to adhere it to the frame.
    • You may have to fold the cable slightly to get it to fit in its recess.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,075 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,784개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 16
전체 시간: 227
