주요 콘텐츠로 건너뛰기
How to Clean the Rollers in Your Polaroid Flip Camera
필요한 것
  1. How to Clean the Rollers in Your Polaroid Flip Camera, Before you begin: 1 단계, 이미지 3개 중 1개 How to Clean the Rollers in Your Polaroid Flip Camera, Before you begin: 1 단계, 이미지 3개 중 2개 How to Clean the Rollers in Your Polaroid Flip Camera, Before you begin: 1 단계, 이미지 3개 중 3개
    • Before you begin:
    • Unplug all cables from your camera.
    • Fully close the flash unit at the front of the camera to turn it off.
  2. How to Clean the Rollers in Your Polaroid Flip Camera, Open the film door: 2 단계, 이미지 3개 중 1개 How to Clean the Rollers in Your Polaroid Flip Camera, Open the film door: 2 단계, 이미지 3개 중 2개 How to Clean the Rollers in Your Polaroid Flip Camera, Open the film door: 2 단계, 이미지 3개 중 3개
    • Hold down the latch on the left side of the camera and open the film door.
  3. How to Clean the Rollers in Your Polaroid Flip Camera, Clean the rollers: 3 단계, 이미지 2개 중 1개 How to Clean the Rollers in Your Polaroid Flip Camera, Clean the rollers: 3 단계, 이미지 2개 중 2개
    • Lightly dampen a soft, clean cloth with water.
    • Use the cloth to gently clean the entire surface of both rollers, spinning them as necessary.
    • Allow the rollers to dry completely before using your camera again.
결론
If cleaning the rollers doesn't solve your problem, they may be damaged. Follow this guide to replace the film door, which contains the rollers.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,628 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,626개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 189
