주요 콘텐츠로 건너뛰기
Polaroid Flip Film Door Replacement
필요한 것
  1. Polaroid Flip Film Door Replacement, Before you begin: 1 단계, 이미지 3개 중 1개 Polaroid Flip Film Door Replacement, Before you begin: 1 단계, 이미지 3개 중 2개 Polaroid Flip Film Door Replacement, Before you begin: 1 단계, 이미지 3개 중 3개
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Before you begin:
    • Unplug all cables from your camera.
    • Fully close the flash unit at the front of the camera to turn it off.
  2. Polaroid Flip Film Door Replacement, Open the film door: 2 단계, 이미지 3개 중 1개 Polaroid Flip Film Door Replacement, Open the film door: 2 단계, 이미지 3개 중 2개 Polaroid Flip Film Door Replacement, Open the film door: 2 단계, 이미지 3개 중 3개
    • Throughout this guide, directional words (front, back, left, right) are from the perspective of using the camera—or when the lens faces away from you.
    • Hold down the latch on the left side of the camera and open the film door.
  3. Polaroid Flip Film Door Replacement, Remove the bottom shell screw: 3 단계, 이미지 3개 중 1개 Polaroid Flip Film Door Replacement, Remove the bottom shell screw: 3 단계, 이미지 3개 중 2개 Polaroid Flip Film Door Replacement, Remove the bottom shell screw: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
    • The screw is hidden inside the camera on the back edge—you may need to use a flashlight to see it, as well as a skinny, long‑shank screwdriver to reach it.
    • Be careful when removing your screwdriver, as the screw can easily fall inside the camera. If it does, hold the camera above your work surface and gently shake it so the screw falls out.
  4. Polaroid Flip Film Door Replacement, Camera mirror warning: 4 단계, 이미지 2개 중 1개 Polaroid Flip Film Door Replacement, Camera mirror warning: 4 단계, 이미지 2개 중 2개
    • Removing the bottom shell in the next step exposes the camera mirror. Be careful not to smudge it or get any debris on it. If you accidentally do, use a lint‑free cloth to gently wipe the mirror clean.
  5. Polaroid Flip Film Door Replacement, Remove the bottom shell: 5 단계, 이미지 3개 중 1개 Polaroid Flip Film Door Replacement, Remove the bottom shell: 5 단계, 이미지 3개 중 2개 Polaroid Flip Film Door Replacement, Remove the bottom shell: 5 단계, 이미지 3개 중 3개
    • Slide the bottom shell towards the back of the camera to release the clips securing it.
    • Lift and remove the shell.
    • During reassembly:
    • Place the shell onto the frame so it hangs over the back about about half an inch (~13 mm), creating a gap near the center of the camera. This allows room for the clips to slide into place.
    • Push down on the shell and slide it towards the front of the camera to engage the clips—you should feel them slide into place.
  6. Polaroid Flip Film Door Replacement, Remove the film door screws: 6 단계, 이미지 2개 중 1개 Polaroid Flip Film Door Replacement, Remove the film door screws: 6 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 3 mm‑long film door hinge screws (one on either side of the camera).
  7. Polaroid Flip Film Door Replacement, Open the film door: 7 단계, 이미지 3개 중 1개 Polaroid Flip Film Door Replacement, Open the film door: 7 단계, 이미지 3개 중 2개 Polaroid Flip Film Door Replacement, Open the film door: 7 단계, 이미지 3개 중 3개
    • Open the film door and place a clean cloth in the compartment.
    • This prevents the door from re‑securing when detaching it.
  8. Polaroid Flip Film Door Replacement, Unclip the film door: 8 단계, 이미지 3개 중 1개 Polaroid Flip Film Door Replacement, Unclip the film door: 8 단계, 이미지 3개 중 2개 Polaroid Flip Film Door Replacement, Unclip the film door: 8 단계, 이미지 3개 중 3개
    • The small, plastic grommets inside the film door hinges can easily fall off during this step. Don't lose them—you'll need them for reassembly.
    • Use the flat end of a spudger to push one of the film door hinges away from the camera and off its post.
    • Repeat the process to detach the other hinge.
    • Hold the film door steady so the already detached hinge doesn't slide back into place.
    • Check to see if either of the small, plastic hinge grommets stayed on their posts. If they did, remove them and set them aside.
  9. Polaroid Flip Film Door Replacement, Detach the film door: 9 단계, 이미지 2개 중 1개 Polaroid Flip Film Door Replacement, Detach the film door: 9 단계, 이미지 2개 중 2개
    • Remove the film door.
    • At this point, you can remove the cloth from the film door compartment.
    • Make sure there are grommets installed in the film door hinges. To install them, press the grommets into the film door hinges, with the wide end facing in.
    • Hook one of the hinges on its post and then push the other one into place until it snaps over its post.
결론
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,525 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 238
