We're using contrasting thread in our guide so that you can see it. However, when it comes time for your repair, you'll want to use thread that matches the color of your garment's fabric so that your stitching is less visible.
Continue working across the hole taking stitches under every other row of the knit.
This photo illustrates how the needle should go under every other row of stitches. If you are new to sewing, it is better to take one stitch at a time.
When you get about a centimeter past the hole, pull the needle through until the thread is taut, but not gathering or scrunching the fabric.
Stitch this second row the same way you did the first, but in the opposite direction. This time, go under the rows of knit you previously went over, and vice versa.
When you reach the end of this second row, turn around and continue stitching in the previous direction. Stitch rows back and forth until you have worked about a centimeter past the hole.
Don't forget to pull the thread taut after each stitch. If you are new to sewing, take your time, slowly completing each stitch.
When you have finished sewing rows, take the needle and insert it across the top corner of your stitching at a forty-five degree angle, taking a stitch.
As you begin to pull the needle through you will see a loop form. Catch the loop with your finger.
Insert the needle at a forty-five degree angle to your previous stitching, taking the needle under one row of the knit.
You will begin to stitch over your previous stitches at a forty-five degree angle, just as before. Remember to only stitch through one layer of the garment.
When you come to the edge of your stitches, turn the needle around and begin stitching another line of stitches at a forty-five degree angle alongside the line you just made.
When you have covered all your rows of stitching with lines of stitching at forty-five degrees, check your work to make sure that the fabric is not pulling or gathered anywhere.
If you have a pull or gather, you can flatten it with your finger, allowing the thread to loosen.
