주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sew a Straight Stitch
필요한 것
  1. Sew a Straight Stitch, Sew a Straight Stitch: 1 단계, 이미지 2개 중 1개 Sew a Straight Stitch, Sew a Straight Stitch: 1 단계, 이미지 2개 중 2개
    • Thread your needle and tie a knot in the end of the thread.
    • We're using contrasting thread for visibility, but when you do your repair you will want to use matching thread.
    • Drive the needle through the back of the bottom material.
    • Pull the thread taut.
    댓글 쓰기
  2. Sew a Straight Stitch: 2 단계, 이미지 2개 중 1개 Sew a Straight Stitch: 2 단계, 이미지 2개 중 2개
    • Drive the needle through the back side of the top material.
    • In this case we're sewing a buckle, but you can use this stitch to sew just about anything together.
    • Align the two materials in their final position.
    댓글 쓰기
  3. Sew a Straight Stitch: 3 단계, 이미지 2개 중 1개 Sew a Straight Stitch: 3 단계, 이미지 2개 중 2개
    • Drive the needle down through both layers of material, coming out on the back side of the bottom material. Push the needle out of the material.
    • The closer you drive the needle in to where the thread came up, the smaller the stitch length. Having a smaller stitch length requires more stitches, but creates a stronger seam.
    댓글 쓰기
  4. Sew a Straight Stitch: 4 단계, 이미지 2개 중 1개 Sew a Straight Stitch: 4 단계, 이미지 2개 중 2개
    • Ensure the two layers are correctly aligned.
    • Drive the needle through both layers of fabric from the back side of the bottom material, coming up on the top side of the top material.
    댓글 쓰기
  5. Sew a Straight Stitch: 5 단계, 이미지 3개 중 1개 Sew a Straight Stitch: 5 단계, 이미지 3개 중 2개 Sew a Straight Stitch: 5 단계, 이미지 3개 중 3개
    • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
    • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
    • Slowly start to pull the thread taut. As you pull a loop will form.
    • Draw the needle through the loop and pull the thread taut.
    • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
    댓글 쓰기
  6. Sew a Straight Stitch: 6 단계, 이미지 1개 중 1개
    • Cut any remaining thread and admire your work.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,914 평판
안내서 142개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 25
지난 30일: 107
전체 시간: 5,155
