주요 콘텐츠로 건너뛰기
How to Discharge a Capacitor in Large Machinery
필요한 것
  1. How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: 1 단계, 이미지 3개 중 1개 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: 1 단계, 이미지 3개 중 2개 How to Discharge a Capacitor in Large Machinery, Create a capacitor discharge tool: 1 단계, 이미지 3개 중 3개
    • Inspect your capacitor and note the following:
    • The voltage rating of either your capacitor or the device
    • Where the terminals are located
    • Attach two wires to an incandescent lightbulb—making sure the bulb's voltage rating is greater or equal to the capacitor's.
  2. How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: 2 단계, 이미지 2개 중 1개 How to Discharge a Capacitor in Large Machinery, Discharge the capacitor: 2 단계, 이미지 2개 중 2개
    • Don't touch the two wire leads together during this step, as this could short circuit the capacitor.
    • Lay one wire lead on the head of the terminal.
    • While holding the lead in place, lay the other wire lead on the opposite terminal to complete the circuit.
    • Hold this position for a few seconds or until the lightbulb completely darkens.
  3. How to Discharge a Capacitor in Large Machinery, Check with a multimeter: 3 단계, 이미지 1개 중 1개
    • If you have a multimeter, you can check to see if the capacitor is fully drained.
    • Set the meter to its DC voltage measuring mode and measure across the terminals.
    • Any value under 10 volts means your capacitor is sufficiently drained.
결론
For other general electronics skills, click here.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,232 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 31
지난 7일: 205
지난 30일: 470
전체 시간: 7,125
