주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Disconnect a Car or Truck Battery
필요한 것
    1. How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: 1 단계, 이미지 3개 중 1개 How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: 1 단계, 이미지 3개 중 2개 How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: 1 단계, 이미지 3개 중 3개
      • Before you begin, switch the ignition off and remove the key.
      • Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
      • Put on work gloves and safety goggles if you have them available.
      • In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
      • Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
      댓글 쓰기
    2. How to Disconnect a Car or Truck Battery, Open the hood (bonnet): 2 단계, 이미지 3개 중 1개 How to Disconnect a Car or Truck Battery, Open the hood (bonnet): 2 단계, 이미지 3개 중 2개 How to Disconnect a Car or Truck Battery, Open the hood (bonnet): 2 단계, 이미지 3개 중 3개
      • Most motor vehicle batteries are located in the engine bay, under the hood (a.k.a. bonnet). If your battery is located elsewhere, skip to Step 5.
      • If you're not sure, simply continue reading.
      • Pull the hood release lever. It's usually located inside the car, near the steering wheel.
      댓글 쓰기
    3. How to Disconnect a Car or Truck Battery: 3 단계, 이미지 3개 중 1개 How to Disconnect a Car or Truck Battery: 3 단계, 이미지 3개 중 2개 How to Disconnect a Car or Truck Battery: 3 단계, 이미지 3개 중 3개
      • Raise the hood by simultaneously lifting and pressing up on the hood latch release (usually located beneath the front edge of the hood, near the center or center-right).
      댓글 쓰기
    4. How to Disconnect a Car or Truck Battery: 4 단계, 이미지 3개 중 1개 How to Disconnect a Car or Truck Battery: 4 단계, 이미지 3개 중 2개 How to Disconnect a Car or Truck Battery: 4 단계, 이미지 3개 중 3개
      • At this point, depending on the vehicle, your hood may raise and support itself automatically.
      • If not, use one hand to hold the hood open temporarily while securing the hood with the prop rod:
      • Lift one end of the prop rod up or out to release it from the front area of the engine bay.
      • Swing the end of the prop rod up and slide it into the cutout on the underside of the hood.
      • Make sure the hood is well secured before you let go with your other hand, or it may fall and injure you.
      댓글 쓰기
    5. How to Disconnect a Car or Truck Battery: 5 단계, 이미지 3개 중 1개 How to Disconnect a Car or Truck Battery: 5 단계, 이미지 3개 중 2개 How to Disconnect a Car or Truck Battery: 5 단계, 이미지 3개 중 3개
      • Locate the battery. It's normally rectangular and roughly 8-14" across.
      • The battery may be easy to spot, or it may lie under a plastic cover—usually marked with positive (+) and/or negative (-) symbols.
      • On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
      댓글 쓰기
    6. How to Disconnect a Car or Truck Battery: 6 단계, 이미지 3개 중 1개 How to Disconnect a Car or Truck Battery: 6 단계, 이미지 3개 중 2개 How to Disconnect a Car or Truck Battery: 6 단계, 이미지 3개 중 3개
      • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
      • Always disconnect the negative cable first (before removing the positive cable).
      • The negative terminal may be marked with a minus (-) symbol, or it may be unmarked. The positive terminal is almost always marked with a plus (+) symbol, often in red.
      • If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
      댓글 쓰기
    7. How to Disconnect a Car or Truck Battery: 7 단계, 이미지 2개 중 1개 How to Disconnect a Car or Truck Battery: 7 단계, 이미지 2개 중 2개
      • Remove the cable from the negative battery terminal.
      • When connecting the battery, it is advised to roughen up the battery terminals and clean the cable clamp beforehand.
      • Upon reconnecting the battery, make sure to seal the pole connections with an appropriate terminal grease or terminal spray.
      댓글 쓰기
    8. How to Disconnect a Car or Truck Battery: 8 단계, 이미지 2개 중 1개 How to Disconnect a Car or Truck Battery: 8 단계, 이미지 2개 중 2개
      • Prevent the cable from making accidental contact with the terminal by pushing it aside and/or wrapping the cable clamp with a dry rag.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jeff Suovanen
회원 가입일: 08/06/13
454,165 평판
안내서 259개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 76,241개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 149
지난 30일: 635
전체 시간: 32,445
