주요 콘텐츠로 건너뛰기
How to Exit ZTE Max XL Field Test Mode
  1. How to Exit ZTE Max XL Field Test Mode, How to Exit ZTE Max XL Field Test Mode: 1 단계, 이미지 1개 중 1개
    • Field Test Mode (FTM) can be useful if you perform tests on signal strength, but for most users it prevents some applications to run correctly.
    • The phone screen will display FTM when in the mode.
  2. How to Exit ZTE Max XL Field Test Mode: 2 단계, 이미지 1개 중 1개
    • Hold down the power button for 10 seconds to turn off the phone.
  3. How to Exit ZTE Max XL Field Test Mode: 3 단계, 이미지 1개 중 1개
    • Press the power button until your phone responds to power on the phone.
    • To assure your phone does not stay in FTM, DO NOT press the lower volume button. Pressing of the lower volume button is the reason your phone enters FTM.
  4. How to Exit ZTE Max XL Field Test Mode: 4 단계, 이미지 2개 중 1개 How to Exit ZTE Max XL Field Test Mode: 4 단계, 이미지 2개 중 2개
    • If the phone is still in FTM after the reboot, make sure the lower volume button is not stuck.
    • After the button is unstuck, repeat step three.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Olivia Wolf
회원 가입일: 02/15/18
1,400 평판
안내서 5개를 작성함
UW Stout, Team S8-G2, Ogden Spring 2018 UW Stout, Team S8-G2, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G2
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 27
전체 시간: 858
