주요 콘텐츠로 건너뛰기
How to Fix Bent CPU Pins
필요한 것
  1. How to Fix Bent CPU Pins, Assess the damage: 1 단계, 이미지 2개 중 1개 How to Fix Bent CPU Pins, Assess the damage: 1 단계, 이미지 2개 중 2개
    • Assess the damage and the amount of bent pins by gripping the CPU by the edges and peering down the straight rows of pins to check for abnormalities.
    • Hold the CPU gently and be careful not to bend more pins accidentally with your fingers.
    • Check each row—from both directions—so you have a good idea of which areas you need to work on. For example, look down the pins north to south as well as east to west.
  2. How to Fix Bent CPU Pins, Insert the blade between two rows: 2 단계, 이미지 2개 중 1개 How to Fix Bent CPU Pins, Insert the blade between two rows: 2 단계, 이미지 2개 중 2개
    • A conventional trapezoidal utility razor blade (like one you would find in a box cutter) fits perfectly between the rows of pins. The thickness of the blade matches the necessary gap between the rows.
    • Don't push down into the substrate with the blade, as this could mar the surface.
    • Gently slide the utility blade between two rows of pins.
    • If bent pins block the blade's path, gently bend them upright using the sharp corner of the blade, going one at a time.
  3. How to Fix Bent CPU Pins, Begin to straighten the pins: 3 단계, 이미지 3개 중 1개 How to Fix Bent CPU Pins, Begin to straighten the pins: 3 단계, 이미지 3개 중 2개 How to Fix Bent CPU Pins, Begin to straighten the pins: 3 단계, 이미지 3개 중 3개
    • Once the blade can make it down a full row, tilt the blade side to side to straighten the pins on each flanking row.
    • This motion doesn't require too much force, and should only be used to bend each pin row slightly.
  4. How to Fix Bent CPU Pins, Straighten pins in the opposite direction: 4 단계, 이미지 2개 중 1개 How to Fix Bent CPU Pins, Straighten pins in the opposite direction: 4 단계, 이미지 2개 중 2개
    • Once pins in a row are straight in one direction, they won't necessarily be straight in the other direction.
    • Rotate the CPU 90˚ and slide the blade down a row in the opposite direction.
    • As you push the blade along the row, rock it back and forth, straightening pins along the way.
  5. How to Fix Bent CPU Pins, Work on hard pins: 5 단계, 이미지 3개 중 1개 How to Fix Bent CPU Pins, Work on hard pins: 5 단계, 이미지 3개 중 2개 How to Fix Bent CPU Pins, Work on hard pins: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • If any pins are severely bent, you may need to use a pair of sharp angled tweezers to coax them up to an angle where they can be accessed by the utility blade as you work your way down the row.
    • If you're really in a pinch, you can modify a pair of tweezers to have a slightly curled tip.
    • If you don't have any tweezers handy, you can empty the lead out of a 0.5 mm mechanical pencil and slip the empty tip over a pin, using the pencil body to bend the pin back up into place.
    • Be careful using too much force—the long pencil body will give you more leverage than you realize.
  6. How to Fix Bent CPU Pins, Repeat until the pins are mostly straight: 6 단계, 이미지 1개 중 1개
    • Repeat the last four steps until all rows are as straight as possible.
    • Caution: CPU pins are extremely fragile, and although malleable, can only be bent a finite number of times before they easily break.
  7. How to Fix Bent CPU Pins, Lift the socket locking arm: 7 단계, 이미지 3개 중 1개 How to Fix Bent CPU Pins, Lift the socket locking arm: 7 단계, 이미지 3개 중 2개 How to Fix Bent CPU Pins, Lift the socket locking arm: 7 단계, 이미지 3개 중 3개
    • On your motherboard, lift the socket locking arm out around the locking clip and up to its vertical position.
  8. How to Fix Bent CPU Pins, Match the small triangles: 8 단계, 이미지 3개 중 1개 How to Fix Bent CPU Pins, Match the small triangles: 8 단계, 이미지 3개 중 2개 How to Fix Bent CPU Pins, Match the small triangles: 8 단계, 이미지 3개 중 3개
    • Match the corner of the CPU with a gold triangle to the corner of the motherboard socket that also has a triangle.
    • Grip the CPU by its edges and align it over the socket.
  9. How to Fix Bent CPU Pins, Lower the CPU into the socket: 9 단계, 이미지 3개 중 1개 How to Fix Bent CPU Pins, Lower the CPU into the socket: 9 단계, 이미지 3개 중 2개 How to Fix Bent CPU Pins, Lower the CPU into the socket: 9 단계, 이미지 3개 중 3개
    • Lower the CPU into the socket, ensuring that all pins fall into their matching holes.
    • The pins do not have to be perfectly straight for this to happen, but they have to be close.
    • The CPU should fall into the socket without any pressure. Do not push the CPU into the socket.
    • If the pins don't find their holes immediately, or if only one side goes in, remove the CPU and check its pins again.
    • When installed correctly, the CPU will sit flush with the edges of the socket. There shouldn't be any gaps.
  10. How to Fix Bent CPU Pins, Close the locking tab: 10 단계, 이미지 3개 중 1개 How to Fix Bent CPU Pins, Close the locking tab: 10 단계, 이미지 3개 중 2개 How to Fix Bent CPU Pins, Close the locking tab: 10 단계, 이미지 3개 중 3개
    • Once the pins on your CPU are straight enough to allow it to be installed into the socket, close the locking arm by pulling it down, around the locking tab.
  11. How to Fix Bent CPU Pins, Open and close the locking tab: 11 단계, 이미지 3개 중 1개 How to Fix Bent CPU Pins, Open and close the locking tab: 11 단계, 이미지 3개 중 2개 How to Fix Bent CPU Pins, Open and close the locking tab: 11 단계, 이미지 3개 중 3개
    • Without touching the CPU, repeat the locking/unlocking process on the socket four to five more times.
    • When the socket is locked into place, it "grips" the pins, further aligning and straightening them.
    • That's it! Close the socket's locking arm and proceed with your PC build.
결승점
다른 34명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
155,893 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,746개를 작성함
19가이드 댓글
Ce tutoriel est aussi valable pour les sockets Intel à “matrice de pastilles” (Land Grid Array) sauf que dans le cas d’un socket LGA les pins à relever seront sur le socket plutôt que sur le processeur, mais le principe est le même, j’ai pu sauver une carte mère avec un socket LGA 1155 comme ça.
Exemple de socket LGA ou les pins sont bien visibles : https://upload.wikimedia.org/wikipedia/c...
Les pins sur les sockets sont très petits, mais avec une pincette de précision (visible dans ce tutoriel) comme celle d’iFixit c’est faisable.
Brendan - 답글
English translation: "This tutorial is also valid for Intel Land Grid Array sockets, except that in the case of an LGA socket, the pins to be raised will be on the socket rather than on the processor, but the principle is the same, I was able to save a motherboard with an LGA 1155 socket like that.
Example of an LGA socket where the pins are clearly visible: https://upload.wikimedia.org/wikipedia/c...
The pins on the sockets are very small, but with precision tweezers (visible in this tutorial) like the one from iFixit it is doable."
progamer567 -
It's a valuable guide for those who get into trouble with bent CPU pins.
I have encountered and dealt with such a problem several times. It's not an easy task.
This guide gives readers the knowledge and tool to fix the struggle problem. Especially, step-by-step instruction with clear photos will encourage readers to overcome the problem.
Hsien-Ching Chung - 답글
Thank U :) I’ll fix it.
Klaus Hyr Hansen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 70
지난 7일: 583
지난 30일: 2,450
전체 시간: 229,812
