주요 콘텐츠로 건너뛰기
How to Fix Stick Drift for a PlayStation Dualsense Controller V1
필요한 것
  1. How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 1 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 1 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 1 단계, 이미지 3개 중 3개
    • Insert an opening tool into the bottom right corner of the controller.
    • Lift upwards with the opening tool.
    • Continue using the opening tool to pry up the inner sides of the black rim.
    • Repeat on the opposite side.
  2. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 2 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 2 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 2 단계, 이미지 3개 중 3개
    • Lift the black cover upwards to remove.
  3. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 3 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 3 단계, 이미지 2개 중 2개
    • Insert the opening tool below the L1 button and pry the button away from the controller.
  4. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 4 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 4 단계, 이미지 2개 중 2개
    • Insert the opening tool below the R1 button and pry the button away from the controller.
  5. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 5 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 5 단계, 이미지 2개 중 2개
    • Detach the two middle clips using the opening tool or your fingers.
  6. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 6 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 6 단계, 이미지 2개 중 2개
    • Remove the top right and left 6.4 mm screws using a Phillips #00 screwdriver.
  7. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 7 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 7 단계, 이미지 2개 중 2개
    • Remove the bottom right and left 6.4 mm screws using a Phillips #00 screwdriver.
  8. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 8 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 8 단계, 이미지 2개 중 2개
    • Insert the opening tool in between the sides to open the case.
  9. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 9 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 9 단계, 이미지 2개 중 2개
    • With both hands, pull apart the white bottom case to remove.
  10. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 10 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 10 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a pair of tweezers or your fingers, disconnect the battery from the motherboard.
  11. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 11 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 11 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 11 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to pull the orange ribbon.
    • Remove the 6.4 mm screw using a Phillips #00 screwdriver.
    • Lift the battery bracket.
  12. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 12 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 12 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 12 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to detach the four ribbons from the motherboard.
  13. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 13 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 13 단계, 이미지 2개 중 2개
    • Guide the joysticks through the front case and lift the motherboard.
  14. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 14 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 14 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 14 단계, 이미지 3개 중 3개
    • Remove the joystick covers by pulling straight off.
  15. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 15 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 15 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 15 단계, 이미지 3개 중 3개
    • Use the opening tool to snap open the green tabs.
  16. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 16 단계, 이미지 3개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 16 단계, 이미지 3개 중 2개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 16 단계, 이미지 3개 중 3개
    • Use tweezers to remove the wiper disks.
  17. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 17 단계, 이미지 2개 중 1개 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 17 단계, 이미지 2개 중 2개
    • Using a cotton tip with 99.8% isopropyl alcohol, clean around the black rims of the green tabs and the wiper disks.
결론
다른 70명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Yadsari
회원 가입일: 11/01/23
2,074 평판
안내서 1개를 작성함
CSU Los Angeles, Team 4-8, Kershman Fall 2023 CSU Los Angeles, Team 4-8, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S4G8
1 회원
안내서 6개를 작성함
16가이드 댓글
Just cleaning the carbon track on the potentiometer is not really a long term fix for stick drift. Better fixes would be to either replace the photometers or to replace the complete stick with a hall-effect joy stick.
David Fear - 답글
Do you have a link?
Nora -
I did it, sadly cleaning wasn't enough. So I guess I'll have to replace something.
Riedweg Guillaume - 답글
There is now a real fix for this, hall effect mod by Jun Zheng. About $25 per pair of mods. Check out the guys YouTube, link to his AliExpress store in his video description. Just use the guide here for disassembly. https://youtube.com/@junZeng-520?si=UYbf...
Alex Lao - 답글
Upon reassembly I get the three orange blinks error. Research says there’s a ribbon connection error, is that right? I went through steps again and checked all connections, but no change. Have I short circuited something? Would replacing the potentiometer even fix it at this point? Have I damaged a ribbon? (There is no visible damage).
joe lewis - 답글
댓글 쓰기
조회 통계:
지난 24시간: 101
지난 7일: 782
지난 30일: 3,409
전체 시간: 84,380
