주요 콘텐츠로 건너뛰기
How to Fix a Broken XLR Microphone Cable
필요한 것
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 1 단계, 이미지 3개 중 1개 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 1 단계, 이미지 3개 중 2개 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 1 단계, 이미지 3개 중 3개
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: 2 단계, 이미지 1개 중 1개
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: 3 단계, 이미지 2개 중 1개 How to Fix a Broken XLR Microphone Cable: 3 단계, 이미지 2개 중 2개
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: 4 단계, 이미지 3개 중 1개 How to Fix a Broken XLR Microphone Cable: 4 단계, 이미지 3개 중 2개 How to Fix a Broken XLR Microphone Cable: 4 단계, 이미지 3개 중 3개
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: 5 단계, 이미지 2개 중 1개 How to Fix a Broken XLR Microphone Cable: 5 단계, 이미지 2개 중 2개
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Abbie Zajac
회원 가입일: 01/19/16
203 평판
안내서 1개를 작성함
1가이드 댓글
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 25
지난 30일: 89
전체 시간: 27,039
