주요 콘텐츠로 건너뛰기
How to Fix a Stuck Button in Sharp Calculator
필요한 것
  1. How to Fix a Stuck Button in Sharp Calculator, Button Keys: 1 단계, 이미지 1개 중 1개
    • Turn the power off by pressing a button named 2NDF located in the top-left corner.
    • Press the button named ON/C in the top-right corner.
  2. How to Fix a Stuck Button in Sharp Calculator: 2 단계, 이미지 2개 중 1개 How to Fix a Stuck Button in Sharp Calculator: 2 단계, 이미지 2개 중 2개
    • Flip the calculator over so that the back panel is facing upwards.
    • Remove two 5mm Phillips #0 screws from the battery cover by turning the screwdriver in a counter-clockwise direction.
    • Remove the remaining four 5mm Phillips #0 screws from the back panel cover.
  3. How to Fix a Stuck Button in Sharp Calculator: 3 단계, 이미지 1개 중 1개
    • Remove the battery cover.
    • Insert a spudger into the slot located in the top-right corner and pry the battery out.
  4. How to Fix a Stuck Button in Sharp Calculator: 4 단계, 이미지 1개 중 1개
    • Remove the front panel by sticking an opening tool into a small gap between front and back panel.
    • Push the tool down with force and pry open the right side carefully.
    • Detach the front panel from the back panel by lifting the front board.
    • Separate the front and back panel slowly to avoid damaging the LCD ribbon.
  5. How to Fix a Stuck Button in Sharp Calculator: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws from the motherboard.
  6. How to Fix a Stuck Button in Sharp Calculator: 6 단계, 이미지 2개 중 1개 How to Fix a Stuck Button in Sharp Calculator: 6 단계, 이미지 2개 중 2개
    • Lift the motherboard by holding both sides and placing it on the top panel.
    • Lift the grey padding upwards by holding any corner and place it on top of the motherboard.
    • Press the grey padding and put pressure downward to avoid sticking from physical buttons.
  7. How to Fix a Stuck Button in Sharp Calculator: 7 단계, 이미지 2개 중 1개 How to Fix a Stuck Button in Sharp Calculator: 7 단계, 이미지 2개 중 2개
    • Use a spudger to flip, remove, and adjust the position of buttons.
    • Ensure the placement of buttons is correct. Use STEP 1 Image as a reference to the location of buttons.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Micah Bustamante
회원 가입일: 05/08/20
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 30
전체 시간: 5,426
