주요 콘텐츠로 건너뛰기
How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan
필요한 것
  1. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan, How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 1 단계, 이미지 2개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan, How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 1 단계, 이미지 2개 중 2개
    • Prior to starting, turn off and unplug the fan.
  2. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 2 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 2 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 2 단계, 이미지 3개 중 3개
    • Remove the clamp on one side of the fan by turning it counterclockwise.
    • When the clamp is loose enough to be removed, hold the fan cage with your other hand to prevent it from falling right off.
    • Repeat the above process for the other clamp.
  3. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 3 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 3 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 3 단계, 이미지 3개 중 3개
    • Separate the base from the cage of the fan.
  4. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 4 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 4 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 4 단계, 이미지 3개 중 3개
    • Place the fan on the tabletop so that the front grille is facing you.
    • Identify the location of the five screws.
    • This step is crucial because we will want to unscrew the grille diagonally.
    • Unscrew any one of the screws using a Phillips #2 screwdriver.
    • It might also help to hold the fan down with your other hand to avoid movement.
  5. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 5 단계, 이미지 2개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 5 단계, 이미지 2개 중 2개
    • Push up the screw from the bottom to pop it out.
  6. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 6 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 6 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 6 단계, 이미지 3개 중 3개
    • Unscrew the screw located diagonally across from the previous one using a Phillips #2 screwdriver.
    • Diagonally across ensures that the front grille does not experience unequal pressure to help its shape stay intact.
    • Repeat the process for all of the screws.
  7. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 7 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 7 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 7 단계, 이미지 3개 중 3개
    • Remove the front grille from the fan.
  8. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 8 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 8 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 8 단계, 이미지 3개 중 3개
    • Expose the four screws on the impeller assembly by turning the blades.
    • Pick one screw and tighten it a small amount by rotating the screw just once with a Phillips #2 screwdriver.
  9. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 9 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 9 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 9 단계, 이미지 3개 중 3개
    • Move to the screw located diagonally across from the previous one.
    • Tighten the screw the exact same amount as the previous one.
    • Perform the same process for the remaining two screws.
    • Don't overtighten the screws. If the screws are too tight, it might lead to fan vibration.
  10. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 10 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 10 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 10 단계, 이미지 3개 중 3개
    • To ensure that the blades do not move, use one hand to keep them in place.
    • Tighten the set screw between the blades and impeller assembly using a Phillips #2 screwdriver.
    • The set screw is a little hard to reach, so it is crucial to keep the blades still.
  11. How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 11 단계, 이미지 3개 중 1개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 11 단계, 이미지 3개 중 2개 How to Fix a Wobbly Westinghouse 12-inch High Velocity Fan: 11 단계, 이미지 3개 중 3개
    • Check the tightness of the set screw by pulling the blades up gently.
    • The blades should only lift a minuscule amount when you perform this test. If they do not move at all, the set screw is too tight.
결론
작성자
1다른 기여자 명과 함께
Muhammad Ali Malik
회원 가입일: 09/13/20
193 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 596
