소개
If your shirt, dress, or other garment is too tight around your upper arm, use this guide to install a gusset to enlarge that area of the garment. This allows for a better fit and greater freedom of movement, and can help prolong the life of your garment.
Steps 5 and 6 require you to sew using a straight stitch and a zig-zag stitch respectively. If you do not already know how to make these stitches, the following guides can show you the basic method for each:
This guide will demonstrate the method using a sewing machine, but this repair can also be completed with a handheld needle and thread following the same steps.
Before using this guide, make sure your garment has been cleaned and pressed/ironed, as this will provide the best results during your repair.
필요한 것
Use tailor's chalk to mark 4 inches from the seam joining the sleeve to the bodice on the center sleeve seam.
Use tailor's chalk to mark 4 inches from the seam joining the sleeve to the bodice on the bodice seam.
Create a pattern by drawing a diamond that is 4 inches by 3 inches on a piece of paper.
Add an additional half inch to each side for seam allowance.
Cut out your pattern using scissors.
On a piece of similarly-colored fabric, pin your pattern using sewing pins to hold it still on the fabric.
Using fabric scissors, cut out a diamond-shaped piece of fabric following the pattern you created. This is your gusset.
