주요 콘텐츠로 건너뛰기
How to Install a New Battery in Your Google Pixel 8 Pro
필요한 것
  1. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: 1 단계, 이미지 3개 중 1개 How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: 1 단계, 이미지 3개 중 2개 How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • In order for the battery to properly adhere, you must remove all the old adhesive and its residue.
    • Use the flat end of a spudger to scrape up and remove all the old adhesive from the frame.
    • If you're having trouble, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to the adhesive and scrape it up.
    • Use your fingers or tweezers to pick off big chunks.
  2. How to Install a New Battery in Your Google Pixel 8 Pro, Remove the old adhesive residue: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Once you've removed all the old adhesive, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to any residue left on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: 3 단계, 이미지 2개 중 1개 How to Install a New Battery in Your Google Pixel 8 Pro, Temporarily reconnect the battery: 3 단계, 이미지 2개 중 2개
    • Lay the battery in its recess and temporarily reconnect it to the logic board to check its fit and cable length before adhering it.
    • Once you've found the proper alignment, disconnect the battery and remove it.
  4. How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: 4 단계, 이미지 3개 중 1개 How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: 4 단계, 이미지 3개 중 2개 How to Install a New Battery in Your Google Pixel 8 Pro, Install the battery: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • If your battery comes with adhesive pre-installed, remove the plastic liner and firmly press the battery into its recess to secure it with the adhesive.
    • If your battery doesn't have pre-installed adhesive, apply strips of double-sided tape such as Tesa Tape where the old adhesive was and firmly press the battery into its recess to secure it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,114 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,784개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 118
전체 시간: 2,051
