주요 콘텐츠로 건너뛰기
How to Install a New Battery in Your Samsung Galaxy S22 Ultra
필요한 것
  1. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Clean the frame: 1 단계, 이미지 1/2 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Clean the frame: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use your fingers or tweezers to peel up and remove any large pieces of adhesive from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (greater than 90%) to the remaining adhesive.
    • Use the flat end of a spudger to scrape off all remaining adhesive.
  2. How to Install a New Battery in Your Samsung Galaxy S22 Ultra: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Apply a few more drops of highly-concentrated isopropyl alcohol (greater than 90%) to any adhesive residue on the frame and wipe it away with a microfiber or lint-free cloth.
  3. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: 3 단계, 이미지 1/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: 3 단계, 이미지 2/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Measure and cut the tape: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $2.99
    구매
  4. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: 4 단계, 이미지 1/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: 4 단계, 이미지 2/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Apply the strips of tape: 4 단계, 이미지 3/3
    • Lay a strip of tape onto the frame.
    • Use the flat end of your spudger to press down firmly along the whole strip to secure it.
    • Use tweezers to remove the liner from the strip of tape.
  5. How to Install a New Battery in Your Samsung Galaxy S22 Ultra: 5 단계, 이미지 1/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra: 5 단계, 이미지 2/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra: 5 단계, 이미지 3/3
    • Repeat the previous step to apply the remaining strips of tape.
  6. How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: 6 단계, 이미지 1/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: 6 단계, 이미지 2/3 How to Install a New Battery in Your Samsung Galaxy S22 Ultra, Secure the battery: 6 단계, 이미지 3/3
    • While holding the battery above its recess, reconnect the battery cable.
    • This ensures the battery is properly aligned.
    • Lay the battery into its recess in the frame.
    • Press down firmly on the entire surface of the battery to secure it with the tape.
    • Disconnect the battery.
    • Return to your repair guide and continue reassembly.
결론
For optimal performance, calibrate your newly installed battery after completing your repair.
Spencer Day
회원 가입일: 09/14/22
54,795 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,269개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 25
30일 전: 184
전체 시간: 1,189
