소개
Use this guide to open your Logitech MX Anywhere 2 mouse.
Open your mouse to clean its internals, troubleshoot mechanical problems, or replace a part.
필요한 것
Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
Heat an iOpener and apply it to the mouse feet for about two minutes.
Insert an opening pick between a mouse foot and the lower case.
Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
Repeat the previous two steps to remove the remaining mouse feet.
Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Use a Phillips screwdriver to remove the four 5.9 mm-long screws securing the lower case to the upper shell.
Flip your mouse over and grab the upper shell.
Lift the front edge of the upper shell upwards.
Lift the upper shell straight off of the mouse.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Danke für diese Anleitung - war sehr nützlich!
hat sehr gut funktioniert. Auch der Tip mit dem Heißmachen war wichtig für die Weiterverwendbarkeit der Mausfüße
