소개
Use this guide to open your Logitech MX Master 2S mouse.
Open your mouse to clean its internals, troubleshoot mechanical problems, or replace a part.
필요한 것
Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
Apply a heated iOpener to the left and right mouse feet for about one minute each.
Insert an opening pick between the left foot and the lower case.
Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
Insert and slide your opening pick under the right foot to separate its adhesive.
Remove the right mouse foot.
이 단계에 사용된 도구:Tweezers$4.99
Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Use a Phillips screwdriver to remove the four 6 mm‑long screws securing the lower half of the lower case.
Use a T5 Torx driver to remove the two 4.3 mm‑long screws securing the upper half of the lower case.
Insert your opening pick into the seam between the thumb rest and the lower case.
Pry your pick upwards and pull the upper shell away from the lower case with your free hand until you see the gesture button clip release.
Insert your opening pick between the rear of the upper shell and the lower case.
Slide your pick right, away from the thumb rest and pry upwards to release the two clips securing the rear of the upper shell.
Lift the upper shell away from the lower case and lay it on the thumb rest side.
Use the point of a spudger to flip up the white locking flap on the interconnect cable's ZIF connector.
Pull the cable straight out of its socket.
다른 3명이 해당 안내서를 완성하였습니다.
