주요 콘텐츠로 건너뛰기
How to Open Your Logitech MX Master 3S
필요한 것
  1. How to Open Your Logitech MX Master 3S, Soften the mouse feet adhesive: 1 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Soften the mouse feet adhesive: 1 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Soften the mouse feet adhesive: 1 단계, 이미지 3개 중 3개
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. How to Open Your Logitech MX Master 3S, Separate the mouse foot adhesive: 2 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Separate the mouse foot adhesive: 2 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Separate the mouse foot adhesive: 2 단계, 이미지 3개 중 3개
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. How to Open Your Logitech MX Master 3S, Remove the remaining feet: 3 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Remove the remaining feet: 3 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Remove the remaining feet: 3 단계, 이미지 3개 중 3개
    • Repeat the previous two steps for the three remaining feet.
    • The front foot doesn't cover any screws—if you're only removing the mouse feet to open up the mouse, you don't need to remove this foot.
  4. How to Open Your Logitech MX Master 3S, Reassembly information: 4 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Reassembly information: 4 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Reassembly information: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free or microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  5. How to Open Your Logitech MX Master 3S, Unfasten the lower case: 5 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the bottom half of the lower case.
    • Use a T5 Torx driver to remove the one 4.2 mm‑long screw securing the top half of the lower case.
  6. How to Open Your Logitech MX Master 3S, Release the left clips: 6 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Release the left clips: 6 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Release the left clips: 6 단계, 이미지 3개 중 3개
    • Insert your opening pick into the seam between the thumb rest and the lower case.
    • Slide your pick right, towards the rear of the upper shell and pry upward to release the left clips.
  7. How to Open Your Logitech MX Master 3S, Release the right clips: 7 단계, 이미지 2개 중 1개 How to Open Your Logitech MX Master 3S, Release the right clips: 7 단계, 이미지 2개 중 2개
    • Gently pry the upper shell and lower case apart to release the clips on the right side of the mouse.
    • Don't try to fully remove the top shell just yet—another clip and a delicate cable connect the upper shell to the lower case.
  8. How to Open Your Logitech MX Master 3S, Release the final clip: 8 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Release the final clip: 8 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Release the final clip: 8 단계, 이미지 3개 중 3개
    • Lay your mouse down onto your work surface, making sure none of the clips re-engage.
    • Grasp the upper shell and partially lift up the right edge.
    • Pull the upper shell up and back to release the final clip and separate the upper shell from the lower case.
    • Still keep the two halves close together—a cable is still tethered to the upper shell.
    • To reinstall the upper shell, slide the front edge into place first, then press down around the perimeter of the upper shell to engage the remaining clips.
  9. How to Open Your Logitech MX Master 3S, Reposition the upper shell: 9 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Reposition the upper shell: 9 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Reposition the upper shell: 9 단계, 이미지 3개 중 3개
    • Be careful not to strain the cable connecting the upper shell to the lower case.
    • Lift the upper shell away from the lower case and lay it to the right of the mouse.
  10. How to Open Your Logitech MX Master 3S, Disconnect the interconnect cable: 10 단계, 이미지 3개 중 1개 How to Open Your Logitech MX Master 3S, Disconnect the interconnect cable: 10 단계, 이미지 3개 중 2개 How to Open Your Logitech MX Master 3S, Disconnect the interconnect cable: 10 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to gently lift up the sliding lock on the interconnect cable socket.
    • Slide the cable straight out of its socket on the motherboard.
    • During reassembly, insert the cable into the socket with its blue tab facing out, then push down the sliding lock to secure the cable.
  11. How to Open Your Logitech MX Master 3S, Remove the upper shell: 11 단계, 이미지 1개 중 1개
    • Remove the upper shell from the lower case.
결론
Repair didn’t go as planned? Check out our Answers community for help.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
95,353 평판
안내서 465개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
7가이드 댓글
Is the upper shell the MX Master 3s same as the upper shell of the MX Master 3?
Ralph Espinosa - 답글
Yes. I replaced the really grimy grey upper of my MX master 3s with the black upper of a regular MX master 3.
BrandonBELB -
Can you show us how to replace the left click button?
Allen Wong - 답글
Agree, and spare parts for the left buttons would be even better!
Javier Diego Fernández -
Kailh 6x6x7.3 red button
diver 666 -
댓글 쓰기
조회 통계:
지난 24시간: 70
지난 7일: 614
지난 30일: 2,819
전체 시간: 55,220
