주요 콘텐츠로 건너뛰기
How to Open and Clean an Xbox Series X
필요한 것
동영상 개요
  1. How to Open and Clean an Xbox Series X, Uncover the back panel screws: 1 단계, 이미지 2개 중 1개 How to Open and Clean an Xbox Series X, Uncover the back panel screws: 1 단계, 이미지 2개 중 2개
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. How to Open and Clean an Xbox Series X: 2 단계, 이미지 3개 중 1개 How to Open and Clean an Xbox Series X: 2 단계, 이미지 3개 중 2개 How to Open and Clean an Xbox Series X: 2 단계, 이미지 3개 중 3개
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. How to Open and Clean an Xbox Series X, Remove the back panel screws: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. How to Open and Clean an Xbox Series X, Unclip the back panel: 4 단계, 이미지 3개 중 1개 How to Open and Clean an Xbox Series X, Unclip the back panel: 4 단계, 이미지 3개 중 2개 How to Open and Clean an Xbox Series X, Unclip the back panel: 4 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. How to Open and Clean an Xbox Series X: 5 단계, 이미지 2개 중 1개 How to Open and Clean an Xbox Series X: 5 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. How to Open and Clean an Xbox Series X, Remove the back panel: 6 단계, 이미지 3개 중 1개 How to Open and Clean an Xbox Series X, Remove the back panel: 6 단계, 이미지 3개 중 2개 How to Open and Clean an Xbox Series X, Remove the back panel: 6 단계, 이미지 3개 중 3개
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. How to Open and Clean an Xbox Series X: 7 단계, 이미지 3개 중 1개 How to Open and Clean an Xbox Series X: 7 단계, 이미지 3개 중 2개 How to Open and Clean an Xbox Series X: 7 단계, 이미지 3개 중 3개
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. How to Open and Clean an Xbox Series X, Remove the fan screws: 8 단계, 이미지 1개 중 1개
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. How to Open and Clean an Xbox Series X, Disconnect the fan cable: 9 단계, 이미지 3개 중 1개 How to Open and Clean an Xbox Series X, Disconnect the fan cable: 9 단계, 이미지 3개 중 2개 How to Open and Clean an Xbox Series X, Disconnect the fan cable: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. How to Open and Clean an Xbox Series X, Remove the fan: 10 단계, 이미지 2개 중 1개 How to Open and Clean an Xbox Series X, Remove the fan: 10 단계, 이미지 2개 중 2개
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. How to Open and Clean an Xbox Series X, Clean the fan: 11 단계, 이미지 2개 중 1개 How to Open and Clean an Xbox Series X, Clean the fan: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Dust Blower
    $18.99
    • Over time, dust will build up inside the fan and on the fan blades.
    • Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
    • Use a small dust blower or light compressed air to blow remaining dust off of the fan.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • If there's a layer of grime on the fan blades, use soapy water on a damp rag or an isopropyl alcohol wipe to clean it off.
  12. How to Open and Clean an Xbox Series X, Clean the exterior panels and vent holes: 12 단계, 이미지 2개 중 1개 How to Open and Clean an Xbox Series X, Clean the exterior panels and vent holes: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Use a clean rag or microfiber cloth to wipe both sides of the back panel clean.
  13. How to Open and Clean an Xbox Series X, Clean the heatsink: 13 단계, 이미지 1개 중 1개
    • The Xbox Series X draws air up through the large heatsink fins, and they may clog with dust and debris over time.
    • Use a dust blower to blow out any trapped dust from both sides of the heatsink fins.
    • If you need to remove the heatsink for deeper cleaning, follow this guide.
  14. How to Open and Clean an Xbox Series X, Clean hard-to-reach areas: 14 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Brush
    $2.99
    • Depending on how dirty the inside of your console is, you might need to use a soft bristle brush to dislodge more dust and grime.
    • Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas.
    • Once most dust is dislodged, use a dust blower to blow it out of the console.
    • Remember: use this time to clean any other dirty internal surfaces before you seal your console back up. Happy gaming!
결론
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
다른 41명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Arty
회원 가입일: 10/27/19
31,189 평판
안내서 108개를 작성함
5가이드 댓글
i Congratulate You Because taught me how to properly clean my Xbox.
my ubit - 답글
Sehr geil...🤙🤙🤙🙏👍
Andreas Nützmann - 답글
Thanks for this walk through. My xbox was dead but I needed to get into it to get the disc drive out to remove a game. Your guide made it super easy!
Debra Wilson - 답글
Vielen Dank für diese gute Anleitung! Ich konnte dadurch meine Series X öffnen und einen Haufen Staub entfernen.
Joschua - 답글
Merci pour ce tutoriel.
Toujours bien davoir une aide lorsque l'on veut nettoyer sa console.
Au moins ce n'est pas extrêmement compliqué (comme l'était par exemple la 360 avec en plus sont problème de surchauffe...)
Nico - 답글
댓글 쓰기
조회 통계:
지난 24시간: 260
지난 7일: 1,626
지난 30일: 8,747
전체 시간: 123,175
