주요 콘텐츠로 건너뛰기
How to Reapply Durable Water Repellent Finish to a Waterproof Jacket
필요한 것
  1. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket, How to Test Outerwear for Water Repellency: 1 단계, 이미지 1/2 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket, How to Test Outerwear for Water Repellency: 1 단계, 이미지 2/2
    • Lay your jacket on a table or flat surface.
    • Spray the jacket with water.
  2. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 2 단계, 이미지 1/2 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 2 단계, 이미지 2/2
    • Observe the water.
    • If the water sinks in and absorbs into the material, your jacket is "wetting out" and needs to have the durable water repellent finish reapplied.
  3. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 3 단계, 이미지 1/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 3 단계, 이미지 2/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 3 단계, 이미지 3/3
    • If the water beads up, staying on the outside of the garment like dew drops, your jacket does not need to have the durable water repellent finish reapplied.
    • Water droplets should roll right off of the jacket when you pick it up.
  4. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket, How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 4 단계, 이미지 1/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket, How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 4 단계, 이미지 2/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket, How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 4 단계, 이미지 3/3
    • Zip up all the zippers on your jacket.
    • Place your jacket into the washer.
  5. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 5 단계, 이미지 1/2 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 5 단계, 이미지 2/2
    • Add durable water repellency treatment to the wash, following the instructions on the bottle.
  6. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 6 단계, 이미지 1/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 6 단계, 이미지 2/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 6 단계, 이미지 3/3
    • Set the load size to small.
    • Set the water temperature to warm/cold.
    • Run the washer on a normal cycle setting.
  7. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 7 단계, 이미지 1/1
    • When the cycle is finished, run the washer on the rinse setting.
  8. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 8 단계, 이미지 1/2 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 8 단계, 이미지 2/2
    • Take the jacket out of the washer.
    • Place the jacket in the dryer.
  9. How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 9 단계, 이미지 1/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 9 단계, 이미지 2/3 How to Reapply Durable Water Repellent Finish to a Waterproof Jacket: 9 단계, 이미지 3/3
    • Set the dryer to a normal heat setting.
    • Be sure your dryer is on a tumble setting if your normal cycle does not tumble the clothes.
    • If you don't have a dryer, use an iron on a low setting to heat-set the water repellency treatment.
    • Start the dryer.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
2 댓글
Can you recommend a durable water repellency treatment? I have tried to treat my rain jacket in the past and have been disappointed in the results.
Andrea Jeffery - 답글
If fabric becomes wet, it loses its performance and breathability indeed. Therefore, most technical garments contain a tiny layer of Durable Water Repellency (DWR) coating outside. This layer of liquid prevents dirt, grease, oil, and water as well. But, usually, protecting this essential fabric layer becomes very difficult yet.
Therefore, some people use the best waterproofing spray for the outdoor fabric to protect this liquid coating. These waterproofing sprays protect our footwear, and other clothing stuffs from water damage. Though this spray’s main function is to prevent water and form a protective barrier against sun and dirt, it has more benefits than one. These waterproofing sprays improve the performance of your fabrics.
For More Information & Products Review and Buying Guide Visit - https://www.bestoutdoorreview.com/best-w...
Best Outdoor Review - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 33
30일 전: 139
전체 시간: 22,179
