주요 콘텐츠로 건너뛰기
How to Wash a Waterproof Jacket
필요한 것
  1. How to Wash a Waterproof Jacket, Wipe away dirt and debris: 1 단계, 이미지 2개 중 1개 How to Wash a Waterproof Jacket, Wipe away dirt and debris: 1 단계, 이미지 2개 중 2개
    • Look over your jacket and wipe away dirt and debris.
    • For stubborn stains, spot clean using a mild soap or rubbing alcohol. See Spot Cleaning Technical Gear for more details.
  2. How to Wash a Waterproof Jacket, Prepare your jacket: 2 단계, 이미지 3개 중 1개 How to Wash a Waterproof Jacket, Prepare your jacket: 2 단계, 이미지 3개 중 2개 How to Wash a Waterproof Jacket, Prepare your jacket: 2 단계, 이미지 3개 중 3개
    • Zip up the main zipper.
    • Leave pockets unzipped so they can be cleaned inside.
    • Empty all pockets. Check for trash, treasures, or forgotten tissues.
    • Loosen drawstrings and drawcords.
    • Fasten any hook-and-loop closures in their most relaxed position to avoid snagging.
  3. How to Wash a Waterproof Jacket, Load the washing machine: 3 단계, 이미지 1개 중 1개
    • Place your jacket in the washing machine.
    • Add 1-3 jackets at a time. Avoid overfilling the drum—technical garments need room to move freely in the wash.
    • Ideally, use a front-loading washer.
    • Top-loaders usually have agitators, a rotating spindle that creates friction to clean your gear. Jackets can get caught in that spindle, leading to tangles, tears, or scratches.
    • If you don’t have a washing machine, hand-washing is a great alternative. You'll still need a dryer or iron to heat-set afterward!
  4. How to Wash a Waterproof Jacket, Add detergent: 4 단계, 이미지 1개 중 1개
    • Add technical gear soap or gentle biodegradable laundry detergent to the washing machine.
    • Patagonia recommends Storm Wash, which is specially formulated for technical outerwear and equipment.
    • For standard detergent, choose one that's liquid, biodegradable, and free of dyes. Look for labels like "organic" or "sensitive skin."
    • Avoid detergent containing fabric softeners, stain removers, perfumes, whiteners, or bleach.
  5. How to Wash a Waterproof Jacket, Set the washing machine: 5 단계, 이미지 2개 중 1개 How to Wash a Waterproof Jacket, Set the washing machine: 5 단계, 이미지 2개 중 2개
    • Set the load size to small or medium, depending on the number of garments you're washing.
    • Set the water temperature to cold or warm.
    • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
    • Set the spin cycle to low.
    • Start the washing machine.
  6. How to Wash a Waterproof Jacket, Tumble Dry: 6 단계, 이미지 3개 중 1개 How to Wash a Waterproof Jacket, Tumble Dry: 6 단계, 이미지 3개 중 2개 How to Wash a Waterproof Jacket, Tumble Dry: 6 단계, 이미지 3개 중 3개
    • Hang the jacket up to drip dry first to remove excess water, then tumble dry on low heat for at least 30 minutes or until the jacket is fully dry.
    • Don't skip the dryer! Heat activates the durable water resistant (DWR) coating.
    • If you don’t have a dryer, you can use an iron to reactivate the DWR. Carefully follow the steps in How to Iron a Waterproof Jacket.
    • Your jacket is clean, dry, and ready for whatever the weather throws your way!
    • Get back out there!
결승점
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Clara Redwood
회원 가입일: 11/12/24
2,544 평판
안내서 18개를 작성함
Patagonia Patagonia 회원
Community
17 회원들
안내서 168개를 작성함
7가이드 댓글
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
Albert Daniel - 답글
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Rachel - 답글
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
Sarah Geers - 답글
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
choffman - 답글
They absolutely will replace it or give you store credit.
Nathan Keirn -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 61
지난 30일: 282
전체 시간: 58,039
