주요 콘텐츠로 건너뛰기
How to Reattach a Broken Table Leg
필요한 것
  1. How to Reattach a Broken Table Leg, How to Reattach a Broken Table Leg: 1 단계, 이미지 1/1
    • Carefully place the table on an even surface and identify the broken parts.
  2. How to Reattach a Broken Table Leg: 2 단계, 이미지 1/1
    • Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
    • You might need some assistance depending on the size of the table.
  3. How to Reattach a Broken Table Leg: 3 단계, 이미지 1/2 How to Reattach a Broken Table Leg: 3 단계, 이미지 2/2
    • Remove the screws from the broken leg.
    • I am using a Mastercraft flathead 3 mm screwdriver in this step. Your screwdriver type will depend on the screw. Follow this guide to learn more about screwdriver types.
    • Remove the broken leg.
    • Use a paper towel to clean the surface of the table and legs.
  4. How to Reattach a Broken Table Leg: 4 단계, 이미지 1/2 How to Reattach a Broken Table Leg: 4 단계, 이미지 2/2
    • Caution: If you have sensitive skin, avoid direct contact with the glue and use gloves before performing this step.
    • Caution: Use adequate ventilation or wear a mask to prevent inhaling the glue fumes.
    • Carefully apply the glue on the part that connects the table and legs.
  5. How to Reattach a Broken Table Leg: 5 단계, 이미지 1/1
    • Press the leg against the glue for few minutes.
    • Allow the glue to dry for at least 10 minutes.
  6. How to Reattach a Broken Table Leg: 6 단계, 이미지 1/1
    • Once the glue is dry, insert the screws.
  7. How to Reattach a Broken Table Leg: 7 단계, 이미지 1/3 How to Reattach a Broken Table Leg: 7 단계, 이미지 2/3 How to Reattach a Broken Table Leg: 7 단계, 이미지 3/3
    • Use an electric drill or a screwdriver to tighten the screws.
  8. How to Reattach a Broken Table Leg: 8 단계, 이미지 1/1
    • Use a paper towel to remove extra glue stains.
    • Allow the table to dry for 24 hours before turning the table.
  9. How to Reattach a Broken Table Leg: 9 단계, 이미지 1/2 How to Reattach a Broken Table Leg: 9 단계, 이미지 2/2
    • After 24 hours, carefully return the table to the original position.
    • Depending on the size of the table, you might need some assistance to turn the table.
결론
Repeat these steps to fix any other broken legs on the table.
다른 한 분이 해당 안내서를 완성하였습니다.
Kunpriya Aggarwal
회원 가입일: 01/17/21
246 평판
안내서 1개 작성함
York University, Team S1-G15, Woodhouse Winter 2021 York University, Team S1-G15, Woodhouse Winter 2021 회원
YORK-WOODHOUSE-W21S1G15
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 61
30일 전: 236
전체 시간: 9,521
