주요 콘텐츠로 건너뛰기
How to Reattach a Broken Table Leg
필요한 것
  1. How to Reattach a Broken Table Leg, How to Reattach a Broken Table Leg: 1 단계, 이미지 1개 중 1개
    • Carefully place the table on an even surface and identify the broken parts.
  2. How to Reattach a Broken Table Leg: 2 단계, 이미지 1개 중 1개
    • Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
    • You might need some assistance depending on the size of the table.
  3. How to Reattach a Broken Table Leg: 3 단계, 이미지 2개 중 1개 How to Reattach a Broken Table Leg: 3 단계, 이미지 2개 중 2개
    • Remove the screws from the broken leg.
    • I am using a Mastercraft flathead 3 mm screwdriver in this step. Your screwdriver type will depend on the screw. Follow this guide to learn more about screwdriver types.
    • Remove the broken leg.
    • Use a paper towel to clean the surface of the table and legs.
  4. How to Reattach a Broken Table Leg: 4 단계, 이미지 2개 중 1개 How to Reattach a Broken Table Leg: 4 단계, 이미지 2개 중 2개
    • Caution: If you have sensitive skin, avoid direct contact with the glue and use gloves before performing this step.
    • Caution: Use adequate ventilation or wear a mask to prevent inhaling the glue fumes.
    • Carefully apply the glue on the part that connects the table and legs.
  5. How to Reattach a Broken Table Leg: 5 단계, 이미지 1개 중 1개
    • Press the leg against the glue for few minutes.
    • Allow the glue to dry for at least 10 minutes.
  6. How to Reattach a Broken Table Leg: 6 단계, 이미지 1개 중 1개
    • Once the glue is dry, insert the screws.
  7. How to Reattach a Broken Table Leg: 7 단계, 이미지 3개 중 1개 How to Reattach a Broken Table Leg: 7 단계, 이미지 3개 중 2개 How to Reattach a Broken Table Leg: 7 단계, 이미지 3개 중 3개
    • Use an electric drill or a screwdriver to tighten the screws.
  8. How to Reattach a Broken Table Leg: 8 단계, 이미지 1개 중 1개
    • Use a paper towel to remove extra glue stains.
    • Allow the table to dry for 24 hours before turning the table.
  9. How to Reattach a Broken Table Leg: 9 단계, 이미지 2개 중 1개 How to Reattach a Broken Table Leg: 9 단계, 이미지 2개 중 2개
    • After 24 hours, carefully return the table to the original position.
    • Depending on the size of the table, you might need some assistance to turn the table.
결론
Repeat these steps to fix any other broken legs on the table.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kunpriya Aggarwal
회원 가입일: 01/17/21
246 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 19
지난 30일: 96
전체 시간: 12,031
