주요 콘텐츠로 건너뛰기
How to Repair Cracks in T-Shirt Print
필요한 것
  1. How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: 1 단계, 이미지 3개 중 1개 How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: 1 단계, 이미지 3개 중 2개 How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: 1 단계, 이미지 3개 중 3개
    • Lay your shirt on a flat surface.
    • Use scissors to cut a piece of parchment paper the same size as the design on your shirt.
    • Insert the piece of parchment paper inside of the shirt and under the design.
    • This is to prevent the acetone from staining.
  2. How to Repair Cracks in T-Shirt Print: 2 단계, 이미지 3개 중 1개 How to Repair Cracks in T-Shirt Print: 2 단계, 이미지 3개 중 2개 How to Repair Cracks in T-Shirt Print: 2 단계, 이미지 3개 중 3개
    • Dampen a cotton ball with the acetone.
    • Gently dab the cotton ball onto the cracked area of the shirt and hold it in place for 1 minute.
    • Remember to always dab, do not rub.
    • Repeat this over the whole area that you wish to restore.
    • Let your shirt set for 3-5 minutes
    • If you're doing a small area, let it set for 2-3 minutes. If it is any bigger, set it for 5 minutes.
  3. How to Repair Cracks in T-Shirt Print: 3 단계, 이미지 3개 중 1개 How to Repair Cracks in T-Shirt Print: 3 단계, 이미지 3개 중 2개 How to Repair Cracks in T-Shirt Print: 3 단계, 이미지 3개 중 3개
    • Cut a piece of parchment paper to match the size of the shirt's design, then place it over the design.
    • Turn on a clothes iron to the highest heat setting with NO steam.
    • Be careful when handling the iron, it gets burning hot!
    • When your iron is ready, place it over the parchment paper and go over the whole design once.
    • Go over the areas that had the cracks for at least 10-15 seconds.
  4. How to Repair Cracks in T-Shirt Print: 4 단계, 이미지 1개 중 1개
    • Now your shirt design should no longer have cracks.
결승점
작성자
1다른 기여자 명과 함께
Sitara Cruz-Cuevas
회원 가입일: 10/14/24
115 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 67
지난 30일: 330
전체 시간: 2,700
