주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair LED Strip Lights
필요한 것
  1. How to Repair LED Strip Lights, How to Repair LED Strip Lights: 1 단계, 이미지 1개 중 1개
    • Find the spot where the lights stop working and where there are four connections labeled in descending order, "12V, R, G, B" with a scissor "cut here" marking and a copper colored backing.
  2. How to Repair LED Strip Lights: 2 단계, 이미지 1개 중 1개
    • With a scissor, cut along the "cut here" line, separating the faulty strip from the working strip.
  3. How to Repair LED Strip Lights: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixHub Smart Soldering Iron
    $79.95
    • Align the new strip next to the working strip and keep them steady. Look at the four connections like a mirror image. R to R, G to G, etc.
    • Use a soldering iron to solder all four connections.
    • Make sure the solder is secured.
  4. How to Repair LED Strip Lights: 4 단계, 이미지 1개 중 1개
    • Once the four connections are soldered securely, plug in the strip and turn the lights to all three colors to ensure that the connections are steady. Now you may place the lights where so desired.
    • If the strips had an adhesive backing, some new adhesive material may be required.
결론
A solder and soldering iron are fairly common and easy to acquire at a hardware store. Extra length of lights may be left over from initial use, use these first before buying more in order to lower costs; be sure you only cut the lights for repair where these 4 pads are they are likely marked by a dotted line across them, this is also where you'll solder them together. In order to put the lights back where they originally were, some form of an adhesive agent may need to be utilized. On the rear side of connection spot you can glue a small piece of cardboard to hold them together.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jacob
회원 가입일: 03/12/21
508 평판
안내서 1개를 작성함
8가이드 댓글
I dont know why this tutorial is rated as difficult, it really isnt.
Andrea Sherville - 답글 공유
Totally agree with Andrea Sherville. This has to be rated easy-moderate as this really isn’t difficult at all.
S Lee - 답글 공유
Thet step 4 was just weird
Israel McGhee - 답글 공유
Huh, I needed this exact guide. That's nuts.
FarmYard Gaming - 답글 공유
El autor dice: Si la soldadura no es una habilidad con la que estés familiarizado, primero debes consultar otra guía sobre los conceptos básicos de la soldadura. Se llama [guía|750|“Cómo soldar y desoldar conexiones”.] el autor no leyó esa guia la soldadura del paso 4 parecen cagadas de paloma
eamig - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 38
지난 7일: 212
지난 30일: 1,195
전체 시간: 161,715
