주요 콘텐츠로 건너뛰기
How to Repair Snapped Eyeglass Arms
필요한 것
  1. How to Repair Snapped Eyeglass Arms, How to Repair Snapped Eyeglass Arms: 1 단계, 이미지 1/2 How to Repair Snapped Eyeglass Arms, How to Repair Snapped Eyeglass Arms: 1 단계, 이미지 2/2
    • Create an organized and efficient workspace arrangement in a well-ventilated area.
  2. How to Repair Snapped Eyeglass Arms: 2 단계, 이미지 1/2 How to Repair Snapped Eyeglass Arms: 2 단계, 이미지 2/2
    • Examine for grains of material on the damaged area that are loose.
    • Use a file to gently remove any material that may cause the connection to be uneven.
  3. How to Repair Snapped Eyeglass Arms: 3 단계, 이미지 1/3 How to Repair Snapped Eyeglass Arms: 3 단계, 이미지 2/3 How to Repair Snapped Eyeglass Arms: 3 단계, 이미지 3/3
    • Arrange the glasses arm firmly in a clamp.
    • Use two clamps to secure the rest of the glasses.
    • Align the edges of the two parts of the glasses arm face to face.
  4. How to Repair Snapped Eyeglass Arms: 4 단계, 이미지 1/2 How to Repair Snapped Eyeglass Arms: 4 단계, 이미지 2/2
    • Squeeze bottle of flux to obtain fluid.
    • Use the bottle to apply flux onto the surrounding area around the broken edges.
    • The flux increases the efficiency of the solder.
  5. How to Repair Snapped Eyeglass Arms: 5 단계, 이미지 1/3 How to Repair Snapped Eyeglass Arms: 5 단계, 이미지 2/3 How to Repair Snapped Eyeglass Arms: 5 단계, 이미지 3/3
    • Caution Hazardous situation which, if not avoided, could result in minor or moderate injury. When you turn on the soldering station do not touch the soldering iron tip because it is extremely hot. Only touch the handle.
    • Plug in and turn on the fume extractor and place it near the soldering area to absorb the fumes.
    • Plug in and turn on the soldering station.
    • Place the solder on the broken area and used the hot iron tip to melt the solder onto the surrounding broken area.
    • Spread solder around the new connecting area and push the edges of the broken arm together.
  6. How to Repair Snapped Eyeglass Arms: 6 단계, 이미지 1/3 How to Repair Snapped Eyeglass Arms: 6 단계, 이미지 2/3 How to Repair Snapped Eyeglass Arms: 6 단계, 이미지 3/3
    • Once the solder has made a strong connection place the hot iron in the metal wire tip cleaner to remove excess solder.
    • Place the hot iron in the iron holder.
    • Turn off the soldering station and fume extractor.
    • Allow the solder to cool and remove the clamps.
  7. How to Repair Snapped Eyeglass Arms: 7 단계, 이미지 1/3 How to Repair Snapped Eyeglass Arms: 7 단계, 이미지 2/3 How to Repair Snapped Eyeglass Arms: 7 단계, 이미지 3/3
    • Press a file or thin blade against the solder in order to remove the excess hardened solder.
    • File against the solder for grains of the solder to fall off the glasses.
    • Don't remove too much solder as that will compromise the integrity of the connection.
  8. How to Repair Snapped Eyeglass Arms: 8 단계, 이미지 1/3 How to Repair Snapped Eyeglass Arms: 8 단계, 이미지 2/3 How to Repair Snapped Eyeglass Arms: 8 단계, 이미지 3/3
    • Thoroughly inspect the repaired area, checking for stability and strength.
    • Test your eyeglasses to ensure they can withstand normal usage.
결론
In conclusion, the "How to Repair Snapped Eyeglass Arms" guide provides a user-friendly and accessible solution for addressing the common issue of snapped eyeglass arms. By guiding users through the identification of damage, the application of epoxy, and the use of popsicle stick supports, the guide empowers individuals to effectively mend their eyeglasses, extending the lifespan of their eyewear and restoring functionality. Emphasizing a comprehensive approach beyond typical joint repairs, this guide fills a crucial gap in eyeglass repair information. Its clear instructions and utilization of readily available materials make the repair process attainable for a broad audience, fostering a sense of self-sufficiency and encouraging proactive maintenance practices for eyeglass longevity.
Anthony Arias
회원 가입일: 10/24/23
157 평판
안내서 1개 작성함
CSU Los Angeles, Team 12-7, Ribeiro Fall 2023 CSU Los Angeles, Team 12-7, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S12G7
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 78
전체 시간: 399
