주요 콘텐츠로 건너뛰기
How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing
필요한 것
  1. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing, Cotton Winter Gloves: 1 단계, 이미지 1/2 How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing, Cotton Winter Gloves: 1 단계, 이미지 2/2
    • Find the hole in your glove.
  2. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 2 단계, 이미지 1/1
    • Using sewing scissors, cut away any loose thread or frayed sections.
    • Removing loose thread or frayed sections will help the sewing process be easier.
  3. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 3 단계, 이미지 1/1
    • Turn the glove inside out.
    • When the glove is turned inside out, it will ensure that the stitching from the repair won't be seen on the outside.
  4. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 4 단계, 이미지 1/1
    • Cut about 24 inches of thread with a color that matches your gloves.
  5. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 5 단계, 이미지 1/1
    • Hold the needle with your thumb and index finger.
    • Insert one end of the thread into the eye of the needle.
    • Pull the thread through the needle about halfway.
    • Working with sewing needles can potentially result in a minor injury.
  6. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 6 단계, 이미지 1/2 How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 6 단계, 이미지 2/2
    • Find both ends of the thread.
    • Line the ends of the thread together.
    • Create a knot at the end of the thread.
  7. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 7 단계, 이미지 1/1
    • Using your dominant hand, insert the needle as close to the edge of the hole as possible.
    • Pull the needle and all of the thread through the glove.
  8. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 8 단계, 이미지 1/2 How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 8 단계, 이미지 2/2
    • Thread the needle to the other side of the glove to create a straight stitch.
    • Repeat steps 7 and 8 until you reach the other end of the hole.
    • How to Sew a Straight Stitch
  9. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 9 단계, 이미지 1/1
    • Insert 3/4 of the needle into the glove.
  10. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 10 단계, 이미지 1/1
    • Wrap the thread around the needle 3 times.
  11. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 11 단계, 이미지 1/1
    • Pull the needle and thread through to make a knot.
  12. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 12 단계, 이미지 1/1
    • Cut the excess thread off.
  13. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: 13 단계, 이미지 1/1
    • Turn the glove around and wear the glove!
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jessie Li
회원 가입일: 02/21/22
337 평판
안내서 1개 작성함
댓글 한 개
I found a typo.
On step 8, it says, "Thread the needle to the other side of the glove." This doesn't make sense. Did you mean PUSH the needle?
You already covered threading the needle in step 3. It's not possible to "thread a needle to the other side" of something.
Jean - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 50
전체 시간: 3,605
